Re: 70 E body window crank plastic washers
[Re: ph23vo]
#2915470
04/26/21 10:29 PM
04/26/21 10:29 PM
Posts: 306 Georgia
69bfan
Georgia
The thin washers were used on the front door window crank handles for the E-Bodies. The Challengers used the 1/4 inch washers and the Cudas used the 1/2 inch washers for the rears.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: 69bfan]
#2915622
04/27/21 11:22 AM
04/27/21 11:22 AM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
so thin in front , and thicker ones in rear thanks
[Re: ph23vo]
#2915889
04/27/21 08:59 PM
04/27/21 08:59 PM
Posts: 306 Georgia
69bfan
Georgia
