Dana 60 oil seal? #2914715
04/25/21 11:50 AM
04/25/21 11:50 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Dana 60 was gave to me and needs oil seals in the axle tubes 481837 is too big. Is there a smaller one I can use? Didn’t have any old ones in it. Number on the tube is 14 95. Any help would be appreciated. Thanks
Re: Dana 60 oil seal? [Re: bobs69] #2914776
04/25/21 02:14 PM
04/25/21 02:14 PM
Which year housing and size (spline count) axles are you needing the seal for?
Re: Dana 60 oil seal? [Re: Cab_Burge] #2914795
04/25/21 02:47 PM
04/25/21 02:47 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
The axles are moser 35 spline. I think the housing is a 95 the inside diameter is 2.30
Re: Dana 60 oil seal? [Re: bobs69] #2916192
04/28/21 04:32 PM
04/28/21 04:32 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
what bearings are you using, mine are sealed and outer "o" ring
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Dana 60 oil seal? [Re: 440lebaron] #2916221
04/28/21 05:49 PM
04/28/21 05:49 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Using sealed bearings with o rings
Re: Dana 60 oil seal? [Re: bobs69] #2916255
04/28/21 07:26 PM
04/28/21 07:26 PM
AndyF Offline
AndyF  Offline
Depends on the ends and the bearings. I'm running Ford Torino ends with Set 20 sealed bearings in my Dana 60 and they don't use an inner seal. Doesn't sound like you have a factory setup so you'll have to figure out what you have and go from there.
Re: Dana 60 oil seal? [Re: AndyF] #2916265
04/28/21 07:45 PM
04/28/21 07:45 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Dana 60 oil seal? [Re: 70sixpkrt] #2916279
04/28/21 08:03 PM
04/28/21 08:03 PM
AndyF Offline
AndyF  Offline
That thread isn't going to help the OP. He says he has 35 spline axles (bigger diameter than stock) and he has 2.30 ID on the axle tubes which is much smaller than stock. My guess is that there isn't a seal that fits his combo which is why it doesn't have seals in it. The 2.30 ID seems a little small. Typical axles would be 3 inch OD with 0.250 wall so 2.500 ID.
