Bench top Valve spring tester recommendation needed #2914571
04/25/21 01:59 AM
04/25/21 01:59 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi,
I wrecked my little hydraulic, squeeze it in the vise, valve spring tester today. I think it's time to step up to a nice benchtop unit. Criteria would be: readily available, accurate, reliable, easy to use.
Does anyone have a recommendation, and which ones should I stay away from?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Bench top Valve spring tester recommendation needed [Re: Hemi_Joel] #2914645
04/25/21 09:51 AM
04/25/21 09:51 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It seems as though I saw an ad where Proform was going to be reproducing the Rimac units.
I’d look into that.
Re: Bench top Valve spring tester recommendation needed [Re: Hemi_Joel] #2914652
04/25/21 10:04 AM
04/25/21 10:04 AM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
LSM makes a really nice billet one for a fair price. Make sure to get the Dial indicator mount with it...it's worth it.
http://lsmproducts.com/lsm_tools/bench_top_valve_spring_testers
Re: Bench top Valve spring tester recommendation needed [Re: KD800X] #2914678
04/25/21 10:36 AM
04/25/21 10:36 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have the LSM and like all their stuff it is top notch. However I can only test seat pressure with it. It does not seem to have enough travel to get to open pressure.
I can't remember the brand but W8/W9 Head Guru Brett Miller uses this one and it looks killer.
Re: Bench top Valve spring tester recommendation needed [Re: 340Cuda] #2914694
04/25/21 11:03 AM
04/25/21 11:03 AM
Minnesota
Minnesota
Wow, that thing looks like the cats! Probably $$$? I need to find out what it is.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Bench top Valve spring tester recommendation needed [Re: Hemi_Joel] #2914723
04/25/21 12:16 PM
04/25/21 12:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
I believe that digital one is made by Buxton.
If for some reason I was going to replace my Rimac, that’s what I’d get.
Re: Bench top Valve spring tester recommendation needed [Re: Hemi_Joel] #2914774
04/25/21 02:04 PM
04/25/21 02:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
I bought a 0 to 1400 Lb. Intercomp digital when my old Rimacs 1000 lb. tester broke several years ago, I don't like the digital dial calipers on it for measuring travel due to the cheesy mounting of it so I'm going to add a 0 to 1.0 standard dial indicator like the Rimacs have up
I don't remember the price of it or who I bought it from blush
Re: Bench top Valve spring tester recommendation needed [Re: Cab_Burge] #2914848
04/25/21 05:32 PM
04/25/21 05:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I lucked out and bought an Intercomp model VST20 with a Goodson tag on it many many years ago listed on Moparts. It’s held down by four 3/8 bolts to my workbench and is one of those tools that will never leave my shop. I would post some pictures but like many have issues doing so on this website and only this website.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bench top Valve spring tester recommendation needed [Re: pittsburghracer] #2914849
04/25/21 05:34 PM
04/25/21 05:34 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Bench top Valve spring tester recommendation needed [Re: pittsburghracer] #2914989
04/25/21 11:35 PM
04/25/21 11:35 PM
Originally Posted by pittsburghracer
My Intercomp looks nothing like that one, I'll try and post a picture and model number of it in the morning, if I remember luck grin
I remember this morning, sorry blush
