Replacing sending unit in-cab tank #2914388
04/24/21 04:14 PM
04/24/21 04:14 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
'79 W150 with in cab tank (yes I promise factory unit on a 1979). My unit is leaking from the top fuel feed nozzle. I THINK it's a pretty straight forward job. Disconnect battery, disconnect wire to sending unit, tap lock ring counter clockwise to loosen, pull out sending unit, put on new rubber gasket, feed in new unit, lock ring by turning clockwise, reconnect wire then battery. Is it this simple? New unit already has sock on it. I'll index it the same as the old one. Thanks. Never installed new one before but with it right at top of tank, seems like it should be a no-brainer, which is perfect for me laugh
Facts are stubborn things.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2914391
04/24/21 04:20 PM
04/24/21 04:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I circled where mine was leaking
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2914405
04/24/21 04:39 PM
04/24/21 04:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Easy job and no need to disconnect the battery. The sending unit wire is a ground.
Re: Replacing sending unit in-cab tank [Re: stumpy] #2914426
04/24/21 06:02 PM
04/24/21 06:02 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you!
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2914525
04/24/21 10:13 PM
04/24/21 10:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Just make sure the "O" ring is in the proper location before you tighten the lock ring or you could cut the "O" ring.
Re: Replacing sending unit in-cab tank [Re: poorboy] #2914532
04/24/21 10:51 PM
04/24/21 10:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It is safer if you use a brass or plastic tool to tap on the ring with. Don't want to create any sparks if you can help it.
Re: Replacing sending unit in-cab tank [Re: stumpy] #2914702
04/25/21 11:24 AM
04/25/21 11:24 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
That makes sense stumpy, good tip. Thank you very much.
Re: Replacing sending unit in-cab tank [Re: poorboy] #2914703
04/25/21 11:25 AM
04/25/21 11:25 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Got it, thank you. I was wondering if it'll try and turn with the lock ring and bind up. As I said, first one I've done because most aren't so easy to get to. Hopefully Thursday when I'm off work.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2914951
04/25/21 09:43 PM
04/25/21 09:43 PM
Guitar Jones Offline
They have tabs that locate them in the tank.
Re: Replacing sending unit in-cab tank [Re: Guitar Jones] #2915031
04/26/21 08:20 AM
04/26/21 08:20 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Oh good thank you.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2915126
04/26/21 11:41 AM
04/26/21 11:41 AM
5thAve Offline
5thAve  Offline
Did you think about putting some JB weld around that line where it leaks? Usually the original senders are better then the afternarket ones are.
I didn't know or think about still having in cab tanks in 79.
Re: Replacing sending unit in-cab tank [Re: 5thAve] #2915207
04/26/21 01:45 PM
04/26/21 01:45 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I did consider JB weld or similar just to keep it on road until I replace, but it might be a permanent solution shruggy. I also looked for a NOS one on ebay, but none right now. I too am leery of aftermarket ones, but this particular seller has sold 100's with 100% feedback, so I decided to take a chance, and he has a 30 day return policy. Hope I don't regret it.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2915231
04/26/21 02:21 PM
04/26/21 02:21 PM
If it were mine I'd clean it up and silver solder that area.
Re: Replacing sending unit in-cab tank [Re: Guitar Jones] #2915239
04/26/21 02:29 PM
04/26/21 02:29 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I can't solder worth a darn lol. I know it's not rocket science but no experience, and last time I tried I just rolled the bead around everywhere but where I wanted it. I'll keep the old sending unit in case new one has to be sent back.
Re: Replacing sending unit in-cab tank [Re: 5thAve] #2915245
04/26/21 02:34 PM
04/26/21 02:34 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
With dual tanks
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2916154
04/28/21 02:42 PM
04/28/21 02:42 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Just my own opinion, but I like the new sending units. The new ones are made from stainless steel (usually) so they do not have the rust pinhole issues the original ones do from condensation in the tank.
And soldering or using JB Weld to fix the leak he has, might just be a bandaid for an undetected internal rust issue along the section of pickup tube still in the tank.
I have pulled some that had either lost a good 6" or so of tube into the tank, or had so many pinholes that they wouldn't pickup fuel anymore. Probably from being parked for long periods of time and allowing the condensation to remain at a set level and do its work.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Replacing sending unit in-cab tank [Re: hp383] #2916173
04/28/21 03:42 PM
04/28/21 03:42 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thanks. New one is definitely stainless. I'll get new sock filter this way also, and as I wrote before seller has sold a ton of these and 100% feedback
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2916363
04/29/21 12:17 AM
04/29/21 12:17 AM
5thAve Offline
5thAve  Offline
I've always found the senders rust from the outside and usually leaks from around the lines is from the solder or other problems.
I guess the other plus of new is you know there will be no problems with the float and with the luck I have I'd skip the new sender and then it's not available anymore when I need it. I've read a ton of problems over the years with aftermarket senders not reading properly or being erratic etc.
Re: Replacing sending unit in-cab tank [Re: 5thAve] #2916529
04/29/21 01:05 PM
04/29/21 01:05 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I did have problems with spectra aftermarket senders. And I have also read about problems with them from other people using them. I am keeping my fingers crossed on this one...not a spectra and lots of good feedback. At least it’s very easy to get to with no dropping the tank and I will send it right back for refund if bad and go plan B. which probably will be finding NOS
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2916582
04/29/21 03:11 PM
04/29/21 03:11 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
vansauto.com sells sending units for a wide variety of the truck applications and any I have used has the correct ohm rating to show the correct level.
