Re: Replacing sending unit in-cab tank
[Re: stumpy]
#2916870
04/30/21 09:45 AM
04/30/21 09:45 AM
Posts: 15,874 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Larry this is a 15 minute job just do it. I understand the sentiment but I’m still waiting on part anyway. Should be here today or tomorrow. New one I bought says all are tested for proper ohms for accuracy and quality. Looking again at my current one I believe someone installed lock ring upside down?
Facts are stubborn things.
[Re: NITROUSN]
#2916877
04/30/21 09:57 AM
04/30/21 09:57 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
You sure? I just removed it. Ring was bent down at lip as if to make it fit under locking lip on tank
[Re: larrymopar360]
#2916952
04/30/21 12:14 PM
04/30/21 12:14 PM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
You are correct, it was on Upside down
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: NITROUSN]
#2917003
04/30/21 02:10 PM
04/30/21 02:10 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The guy that had the truck before me left a lot of things half-azzed. Thanks for assist.
[Re: larrymopar360]
#2918912
05/05/21 03:28 PM
05/05/21 03:28 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I installed sender and lock ring (proper way this time) and now I realize wire was supposed to have a push on connector like one in this picture but it's long gone. I'd like to find another but no luck local parts store or Feebay. I've googled "push on connectors" and so far I don't find. Any specialties stores online anyone knows of? Driving around town looking doesn't sound fun. Stud is M5 - .08. Thanks.
[Re: stumpy]
#2918954
05/05/21 05:01 PM
05/05/21 05:01 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks for the suggestion guys. I wondered about the oil sending unit connectors but none of them list a size. I used to have a bunch of the stuff and I just recently decided to make some more room in the garage and of course now I need one LOL. I tried a connector and nut but the nut does not tighten down tight. I’m going to try o/p sender next 👍
[Re: stumpy]
#2918963
05/05/21 05:11 PM
05/05/21 05:11 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I wouldn’t mind spending this and if the oil sending unit ones aren’t the right size I’ll give this a try. I’m ready to be done with this and move on to other things. I didn’t plan on this being a project. Thanks again.
[Re: 5thAve]
#2919404
05/06/21 04:20 PM
05/06/21 04:20 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Found one on Feebay with help of seller of sending unit. It's listed for A-B-C body cars as repair wire but will fit my truck sender. Woo hoo. I tried all kinds of searches but none included A-B-C body so it didn't come up. $15 and on the way.
[Re: larrymopar360]
#2922530
05/14/21 04:36 PM
05/14/21 04:36 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The plug from vansauto feels very high quality, factory style and fits very snug AND as you can see came with lengthy wire. So glad I was directed there. If yours needs replacing I highly recommend this one and it was under $20. No more gas smell even when the tank is full and I’m getting accurate readings.
