Re: comp cam spring seat cutter instructions
[Re: Hemi_Joel]
#2914187
04/24/21 01:21 AM
04/24/21 01:21 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
I found it on youtube. A drill is ok.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2914191
04/24/21 02:16 AM
04/24/21 02:16 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Be very careful on cutting the seats, I have hit water on stock 340 heads at .030 cut down I don't cut them down any more except the inner step to get it level with the main spring seat for dual springs I use a old Craftsman 5/8 drill motor that turns real slow
[Re: Cab_Burge]
#2914212
04/24/21 08:36 AM
04/24/21 08:36 AM
Posts: 1,821 South Bend
John Brown
South Bend
For many years I dropped a .030 valve spring shim meant for stock spring seats on before I cut for larger diameter springs. When the cutter got down to the shim, the shim would spin and keep the cutter from digging farther down. That was mostly to keep me from hitting water. I normally used a drill press. When assembling the new springs, a standard .030 small diameter shim went down on the bottom to make for a flat surface.
[Re: John Brown]
#2914278
04/24/21 11:43 AM
04/24/21 11:43 AM
Hemi_Joel
Minnesota
Thanks for the replies. I'm not going to increase the depth, I just need to increase the diameter a little bit.
