FHO and Ray Barton who do you like #2913980
04/23/21 04:29 PM
04/23/21 04:29 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
My Hemi parts purchase has come down to 2 gentleman. Tim Banning and Ray Barton. Who do you like and why?
Re: FHO and Ray Barton who do you like [Re: mopar dave] #2914058
04/23/21 07:43 PM
04/23/21 07:43 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
How many ET or MPH records has Tim Banning set?
Re: FHO and Ray Barton who do you like [Re: cuda499] #2914102
04/23/21 09:13 PM
04/23/21 09:13 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The op never said he was looking to set a record so I’m assuming this will be a street performance motor. Either will would be fine. I’ve done business with Tim in the past and he answers the phone and answers questions.
Re: FHO and Ray Barton who do you like [Re: fastmark] #2914110
04/23/21 09:28 PM
04/23/21 09:28 PM
Mt Morris Michigan
Mt Morris Michigan
Thats correct. Not looking to break any records. Just looking to pick up a paper trophy at the track once in a while. Gonna do business with one of these guys and right now i have a much better gut about Tim than Ray, but need to be sure. Building a 572 12:1 street/strip deal. Tim suggested a 590 and he seemed to be very honest as well.
Re: FHO and Ray Barton who do you like [Re: cuda499] #2914112
04/23/21 09:30 PM
04/23/21 09:30 PM
How many have you set, How many for Crower, Stage V, Dart and so on shruggy
Both are excellent parts providers, machined or not up
Re: FHO and Ray Barton who do you like [Re: Cab_Burge] #2914124
04/23/21 09:44 PM
04/23/21 09:44 PM
Mt Morris Michigan
Mt Morris Michigan
Well, the thing that's really bugging me at this point is Tim didn't have anything good to say about that Bill Mitchell aluminum block and Ray seemed to be just fine with it. Something not right with that.
Re: FHO and Ray Barton who do you like [Re: mopar dave] #2914127
04/23/21 09:47 PM
04/23/21 09:47 PM
Tim helps make and sells KB blocks, Ray will use what he can get as long as the customer is happy with those choices, especially on street parts shruggy work
Re: FHO and Ray Barton who do you like [Re: Cab_Burge] #2914137
04/23/21 10:01 PM
04/23/21 10:01 PM
Mt Morris Michigan
Mt Morris Michigan
Tim did say the KB block used 1/2" main and head studs and the BM has something smaller can't remember what size. I'm just about to the point now of pulling the trigger on the KB block. It is a much nicer block no doubt. Tim would be the guy at that point.
Re: FHO and Ray Barton who do you like [Re: mopar dave] #2914145
04/23/21 10:22 PM
04/23/21 10:22 PM
NY
B1duster Offline
B1duster  Offline
NY
Just curious, 590 cubes ?
Re: FHO and Ray Barton who do you like [Re: B1duster] #2914147
04/23/21 10:30 PM
04/23/21 10:30 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, 590.
Re: FHO and Ray Barton who do you like [Re: B1duster] #2914148
04/23/21 10:30 PM
04/23/21 10:30 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've never spoken with Barton but I have done business with Tim. Tim is A#1 in my book and a true gentleman and I'd recommend him in a heartbeat!
Re: FHO and Ray Barton who do you like [Re: mopar dave] #2914151
04/23/21 10:34 PM
04/23/21 10:34 PM
Mt Morris Michigan
Mt Morris Michigan
https://youtu.be/3lE4FFZKiYM Just one mans experience with BM products, but i think it's enough for me. I'll get the KB block ordered from Tim. As for the heads, i'm sure either guy can get me straight with the best match to my combo, but with this kind of money i want the best most knowledgable guy with the best cnc programs.
Re: FHO and Ray Barton who do you like [Re: quickd100] #2914153
04/23/21 10:39 PM
04/23/21 10:39 PM
Mt Morris Michigan
Mt Morris Michigan
That's definatly good to here.
Re: FHO and Ray Barton who do you like [Re: mopar dave] #2914157
04/23/21 10:55 PM
04/23/21 10:55 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
Tim moves the steam holes away from the sleeves so you should use his block,heads and gaskets.
I had a coolant seepage from the steam holes around the sleeves with the BM block, Victor Jr. heads and Cometic gaskets I got from Ray. He said he saw that problem more than a few times when I called him about it.
Re: FHO and Ray Barton who do you like [Re: mopar dave] #2914158
04/23/21 10:55 PM
04/23/21 10:55 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I guess opinions are like assholes everybody has one, I have had a world products aluminum wedge block in my race car for 10 years, best money I ever spent. three years ago I broke a rod and blew it up, Called BM and they gave me all the info, and specs I needed in getting it welded and repaired. Even though they had no blocks to sell me at the time.
Re: FHO and Ray Barton who do you like [Re: jwb123] #2914171
04/23/21 11:42 PM
04/23/21 11:42 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Ok what KB block have you decided on. I keep walking by the big MM Cam KB in the garage and it is so pretty and has so much built into the block. Did you ask Tim about the blocks and what timing belt or chain it takes.The belt is expensive but works and there are other things to talk about with each builder when building a Hemi.There are options now a days. If you are building a good race motor maybe the bigger cam is good but looks like you want a good street motor. I have not heard much about the Bill Mitchell block and how much HP you can put through it. Might be fine but looking at the KB block it sure has a lot more to it. If you wonder about the KB ask Darrel Beal I believe is his name on moparts he did a lot of the work on the new KB Block. Both Ray and Tim both build good products and there are a few others that are on Moparts that build a real good hemi. Ray has more experience with Iron block and heads Super Stock Motors, Banning went to the big motors a long time ago and that is what he is best at, I have seen some awesome Dyno numbers on motors that he has built but these are NSS big cube hemi motors.
1971 HEMI E BODY REGISTRY
Re: FHO and Ray Barton who do you like [Re: hemicar1971] #2914178
04/24/21 12:18 AM
04/24/21 12:18 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I would call Best machine and discuss your goals and let them decide the best avenue to go.
They have built tons of hemi’s and have a very good reputation... and are pretty close to you
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: FHO and Ray Barton who do you like [Re: B3422W5] #2914213
04/24/21 08:41 AM
04/24/21 08:41 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Dave, I really hope you go with a 12:1 588 from Tim, for selfish reasons, because that's exactly my plan when I retire in a couple years.
Although either Ray or Tim put out a quality piece, Tim seems to have the edge when it comes to the pro-street combination.
Re: FHO and Ray Barton who do you like [Re: hemicar1971] #2914214
04/24/21 08:42 AM
04/24/21 08:42 AM
Mt Morris Michigan
Mt Morris Michigan
We mainly talked stage v head, but he did ask me if i was gonna run a belt. I will be using a chain or gear drive. He knows i'm doing a street deal. Since i have the money and the KB is a better block, thats what i'm gonna get. No more wondering or guessing to get a good block.
Re: FHO and Ray Barton who do you like [Re: Moparrob68] #2914217
04/24/21 08:48 AM
04/24/21 08:48 AM
Mt Morris Michigan
Mt Morris Michigan
Thats is nice to know. Tells me Tim is on top of these issues. Just what i'm trying to avoid.
Don: I did speak with Best a few weeks ago because i wanted them to do all the machine work. They didn't say much about the BM block and suggested that i use the Victor head. Looks like all the machining will be done on the KB if i buy from Tim.
