Re: Antenna Question
[Re: Alaskan_TA]
#291409
04/18/09 07:25 AM
04/18/09 07:25 AM
Posts: 733 Long Island NY
yellow sixpack
Long Island NY
Thanks thats what I though my buddy confused me last night on this one. Thanks again.
If you can't be smart.....don't be stupid!
[Re: Alaskan_TA]
#291412
04/18/09 11:47 PM
04/18/09 11:47 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Thanks Barry,
But what is odd is the same antenna that you show in that post is what I removed from a junked out T/A many decades ago to install on my 71 T/A clone,
Plus I seen the solid one peice on a few AAR's and T/A's over the years,.........I don't know what is "correct",.....and if anyone would know it would be you,
Here's the only pic I have of the antenna on the rear of my T/A........I've also seen only one other Trans Am car with the large chrome benzel also, like whats on mine......I created my 71 T/A clone back in 1979,...using original T/A parts, or what FEW repro parts that were available
[Re: Alaskan_TA]
#291418
04/21/09 12:23 AM
04/21/09 12:23 AM
Posts: 1,822 Colorado
denfireguy
Colorado
From the 1970 FSM, obviously a 31" single piece antenna could not be "extended to 40";
Hmmmm, 31 inches is quarter wavelength for the center of the FM band. I wonder where they came up with 40 inches for the FS manual? I noticed in the owners manual they said to wait ten minutes for the radio to "warm up". I am thinking they did not have a lot of experience with transistors at that time. Unless the car was sitting out in the cold.... wait, maybe that is an Alaska owners manual. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#291419
04/21/09 12:28 AM
04/21/09 12:28 AM
Posts: 8,850 Central Coast, Calif.
Snoopy
If you read past the 40", you will see that they were referring to adjusting the antenna trimmer for the AM band not the FM band.
Anyone that was around in 1970 would tell you that AM was king and FM stations were scarce in most parts of the country especially where there were hills or mountains. That's why AM radios were more common than AM-FM radios.
[Re: Snoopy]
#291420
04/21/09 04:51 AM
04/21/09 04:51 AM
Posts: 21,554 N.E. OHIO, USA
A12
N.E. OHIO, USA
Agree with the few FM stations in '69-'71...I had a part time job doing car stereo installations (8-track and a few FM radios) during '69/'70 era and there must have been a handfull at the most in the Pittsburgh area during that time and very limited range with the hills of Western PA. We always set the telescopic antennas to 31" when we installed an FM radio as that was already the "known" best length for FM and worked okay for AM. If you were on a hill late on Sunday night and extended the antenna fully you could get AM radio stations hundreds of miles away but FM seemed to always average at best 50-75 miles....maybe
MikeR
[Re: Snoopy]
#291421
04/21/09 10:09 PM
04/21/09 10:09 PM
denfireguy
Colorado
We were blessed on the Colorado Front Range. We had several great FM stations. KLZ FM played top 40 with album cuts instead of the singles. KFML played just about everything with no rhyme or reason with DJs that sounded like they just woke up from a nap. KLAK FM played country. All of the stations were in stereo and with mountain top transmitters covered the state. That is when I learned to adjust the telescopic antenna on my 68 Fury III to 31 1/4 inches for optimum reception. Retrimmed the AM radio on a station on 1510 for best reception there. I did not listen to much AM then except on long trips. Craig
