Removing rust from fender and inner fender?
#2913940
04/23/21 02:30 PM
04/23/21 02:30 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have a fender and inner fender that have significant amounts of surface rust. So I am looking for the best way to remove the rust before priming and painting... (it's not Mopar but don't tell anyone, hydrated iron oxide is the same compound for all manufacturers) I've got 5 gals of Evaporust but nothing big enough to put the parts in and keep them wet. Also available are: angle grinder with flap disc; wire cup brush; air sander with pad and 80-grit discs. The inner fender appears to be 16-ga (.050) and I'm concerned that blasting would warp it. Suggestions please?
Re: Removing rust from fender and inner fender?
[Re: DrCharles]
#2913993
04/23/21 04:48 PM
04/23/21 04:48 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I would knock the heavy rust off with a brush . Then use the evaporust by putting it in a cheap plastic little kids swimming pool . You could tilt it for more depth , move the part around , keep it wet by brushing / splashing it on in the pool . I have kept the part wet using scotch brite pad . I love the evaporust ! Non toxic mild on bare hands !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#2914068
04/23/21 08:14 PM
04/23/21 08:14 PM
Posts: 5,854 ohio
ruderunner
ohio
Bag it. You're familiar with marinating meat right? This is just really tough piece of meat.
I would run a scraper or wire brush over it first, then bag it and evaporust it.
Blasting would be ok as this isn't an exposed panel, warping wouldn't be noticeable.
Angry white pureblood male
[Re: A/MP]
#2914108
04/23/21 09:24 PM
04/23/21 09:24 PM
DrCharles
West Plains, MO
Thanks everyone. I've used Evaporust before (that's why I bought 5 gal when Amazon had a sale)... but I agree, it is slow especially on heavy rust and cooler temps. Good idea on the bagging, but I'd have to keep turning and agitating it too.
I ended up sanding it with a DA and 40-grit discs, and a pistol-grip sander with a flap disc for the tighter and more curved areas. I tried to stay upwind, and blow off the rust frequently, but I can still taste it...
I also remade the rusted piece, welded it in, cleaned everything and gave it two coats of Rustoleum Rusty Metal Primer, inside and out. Now trying to decide whether to paint the wheel side or just use undercoating on that side (we have lots of gravel roads around here).
The dent is there because it clears the a/c bracket that came from a car with the same engine.
