I have a fender and inner fender that have significant amounts of surface rust. So I am looking for the best way to remove the rust before priming and painting... (it's not Mopar but don't tell anyone, hydrated iron oxide is the same compound for all manufacturers)
I've got 5 gals of Evaporust but nothing big enough to put the parts in and keep them wet. Also available are: angle grinder with flap disc; wire cup brush; air sander with pad and 80-grit discs. The inner fender appears to be 16-ga (.050) and I'm concerned that blasting would warp it.
Suggestions please?
