small block remote oil adapter ?? #2913866
04/23/21 12:15 PM
04/23/21 12:15 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Whats a GOOD adapter for a remote filter that goes on the block ? i see moroso, canton.....
Currently have a Trans Dapt and it sweats too much oil...LOL Motor is dry everywhere else.
....BAD A$$ STREET CAR.....
Re: small block remote oil adapter ?? [Re: n20mstr] #2913893
04/23/21 12:53 PM
04/23/21 12:53 PM
moparx Offline
moparx  Offline
is the one you are using a screw-on, in place of the filter, or a bolt on, like the through bolt used on the small block factory 90* adapter ?
beer
Re: small block remote oil adapter ?? [Re: moparx] #2913899
04/23/21 01:00 PM
04/23/21 01:00 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
beer
Screw on in place of the filter, but i will put on whatever works well. Cant tap any holes as the engine is assembled an in the car running
Re: small block remote oil adapter ?? [Re: n20mstr] #2913903
04/23/21 01:01 PM
04/23/21 01:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: small block remote oil adapter ?? [Re: MR_P_BODY] #2913906
04/23/21 01:07 PM
04/23/21 01:07 PM
moparx Offline
moparx  Offline
i used a screw on piece one time on a big block. it was leak/damp free, using 1/2 NPT threads and normal hydraulic hose and ends.
i don't remember what brand it was, but more than likely a cast cheapy piece. that was in the 1974-78ish time frame.
beer
Re: small block remote oil adapter ?? [Re: MR_P_BODY] #2913910
04/23/21 01:17 PM
04/23/21 01:17 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Originally Posted by MR_P_BODY
YES , thats one of the ones we were considering, Thanks MR P
Re: small block remote oil adapter ?? [Re: n20mstr] #2913936
04/23/21 02:15 PM
04/23/21 02:15 PM
AndyF Offline
AndyF  Offline
Last one I did was fitted with adapters right into the oil passages in the block. That worked great.
Re: small block remote oil adapter ?? [Re: AndyF] #2914043
04/23/21 07:06 PM
04/23/21 07:06 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
Who sells those extended fittings? I'm looking for something like that for a Ritter block
Re: small block remote oil adapter ?? [Re: Moparrob68] #2914073
04/23/21 08:33 PM
04/23/21 08:33 PM
AndyF Offline
AndyF  Offline
BLP sells some but you can also get them from an industrial hose and fitting supplier.
Re: small block remote oil adapter ?? [Re: AndyF] #2919643
05/07/21 11:22 AM
05/07/21 11:22 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I have been using the canton racing units. Very nice. Kinda spendy.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: small block remote oil adapter ?? [Re: AndyF] #2922125
05/13/21 02:27 PM
05/13/21 02:27 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
What filtration is that? Sandwich filter? Flat screen? How many microns and bypass or no? I will be using an Accusump and would like to know these secrets, Andy!
Instagram : @5_points_racing
Re: small block remote oil adapter ?? [Re: JP8] #2922183
05/13/21 06:01 PM
05/13/21 06:01 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It looks like an Oberg filter
https://www.obergfilters.com/
Alan Jones
