Anyone using a larger than 19.25 clutch fan? #291379
04/17/09 09:24 PM
04/17/09 09:24 PM
So Cal
HealthServices Offline OP
Why would you even post that?
So Cal
I think I have a standard 18 and there's available the 19.25" for my 69 Road Runner. Anyone try anything bigger and what did you get it out of?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Anyone using a larger than 19.25 clutch fan? [Re: HealthServices] #291380
04/17/09 09:37 PM
04/17/09 09:37 PM
IN
ahy Offline
ahy  Offline
IN
There was a 19+ (around 19 3/4) 7 blade fan with cupped tips on the BB Cordoba's. If you need to move a lot of air you might try one of those. I got one on a core engine but didn't need it.
Re: Anyone using a larger than 19.25 clutch fan? [Re: ahy] #291381
04/17/09 10:14 PM
04/17/09 10:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I've never switched fans on anything, but do know from experience that a good water pump (aka Edelbrock) sure makes a difference.
If I were in the market for a larger mopar fan and wasn't concerned with it being 100% stock looking I would find something off a 70's or 80's van or pickup. Just from memory the last time I went to the pick-n-pull some of the mopar trucks and vans had jumbo sized fans with rather large curved blades on them. They looked a whole lot more efficient than any of the fixed blade 60's fans for that's for sure.
I have the correct fan for my 70 dart, but am thinking that one of those junkyard fans would pull more air. So long as it fits in the shroud......
