E85 fuel w/o radiator at track? #2913171
04/21/21 09:11 PM
04/21/21 09:11 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Just here thinking if a guy could use E85 in a dragster or altered without a radiator? It runs cooler than gasoline but would it keep the engine cool enought for a 1/4 mile pass. Would filling a block with water and drain down in the pits work as in old days. What's your take or experiences on the subject? Always thinking ahead on possibilities.
Re: E85 fuel w/o radiator at track? [Re: maximus] #2913203
04/21/21 10:40 PM
04/21/21 10:40 PM
My super pro bracket car has two small oil coolers used as the radiator due to having a 7.5 gallon fuel cell mounted up front where the radiator was mounted.
I race it on pump E85 and it doesn't get to hot at the 1/4 mile tracks as long as I watch it and don't let it get above 220 F during the run. I do have to let it run quite a while to get it up to 160 F before driving it into the staging lanes shruggy
It is a low deck 400 block stroke to 511 C.I. and makes a little over 800 HP with one Dominator carb set up for E85 by A.J. at Bob George racing up
8.86 at 150.+ MPH in the 1/4 weighing 2850 with me in it boogie
Don't get me wrong, i have had it up to 240 F after a run and had the puke tank over flow and spill coolant out in my pits after a run realcrazy
Re: E85 fuel w/o radiator at track? [Re: Cab_Burge] #2913206
04/21/21 10:44 PM
04/21/21 10:44 PM
PA
moparacer Offline
moparacer  Offline
PA
On my alky small block dragster I used a 12 inch B&M oil cooler for a radiator. I had my Barracuda on E85 a few years back and although it did run cooler, I don't think its enough to eliminate the radiator. Definitely doesn't run as cool as Alky.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: E85 fuel w/o radiator at track? [Re: maximus] #2913269
04/22/21 06:08 AM
04/22/21 06:08 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
No way I'd ever do it. If it's a bracket car, why would you wanna create more work on race day? Draining the block after each pass, no thanks. I'd find a spot for a small cooler and a fan and never worry about it again.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
