Four piston brake calipers for 69-72 A-body #291283
04/17/09 06:47 PM
04/17/09 06:47 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
I have the early a-body disc brakes on my Demon, I was bleeding the brakes and I didnt have a rotor on one side and a piston came out too far and fluid came out, I used a C clamp to push it back in the leak stopped but I see the rubber boot has come halfway off, anyone know how to slip it back on.thanks
Re: Four piston brake calipers for 69-72 A-body [Re: dodger1] #291284
04/17/09 08:23 PM
04/17/09 08:23 PM
central pa
darted1 Offline
darted1  Offline
central pa
You will probably have to remove the piston and seat the dust cover back into its groove. then re install the piston . I wouldnt force the piston it should push back in by hand, forcing it could cut the o ring and cause a leak.
ED M
Re: Four piston brake calipers for 69-72 A-body [Re: darted1] #291285
04/17/09 08:46 PM
04/17/09 08:46 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
Thanks , does the piston come out by taking the caliper apart or can I just pull it out the front, I appeciate the help
Re: Four piston brake calipers for 69-72 A-body [Re: dodger1] #291286
04/18/09 01:48 AM
04/18/09 01:48 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The pistons come out the way that one came out. If the calipers are old I would put kits in them. The later calipers have to have the piston out to get the dust boot installed correctly. The early (65-67ish) had a different boot style that could be put on with the pistons installed.
