Re: Which Cal-Trac mono leafs?
[Re: Old buddy]
#2912607
04/20/21 08:53 PM
04/20/21 08:53 PM
Posts: 108 WNY
Moparrob68
WNY
I used Cal-Trac +1 mono leafs on my 68 Coronet R/T and the stance is great. I originally ordered the +1 shocks but only had about 1" compression and had to send them back and they swapped out a Std set. Hoosier 29.5 x 12 slicks
[Re: racerx]
#2912692
04/20/21 10:55 PM
04/20/21 10:55 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have Calvert monos at +1” on my b body because i run stock wheelwhels and fit 11” slicks on there and i wasn’t 100% sure if they would fit with stock height springs. I do like the stance with them, but i think the stock height springs would look just as good.
BTW, boy that Coronet R/T above is absolutely gorgeous. Love the color combo!
[Re: Moparteacher]
#2912736
04/21/21 06:53 AM
04/21/21 06:53 AM
Posts: 4,669 Wichita
GY3
Wichita
My next plan is to install wooden spoke wheels of a horse drawn buggy.
Conestoga-Tracs.
[Re: Old buddy]
#2913661
04/22/21 09:53 PM
04/22/21 09:53 PM
Posts: 31,005 Oregon
AndyF
Im putting a 69 road runner together to run low 11s/high 10s. Im removing all of the stock rear suspension and 8 3/4 rear end and am replacing it with a Dana 60, Caltrac Mono Leaf springs, and CalTrac bars. I plan on running a 29" tall tire...which ride height do I need? Stock ride height or +1? Here is a '69 RR with -1 rear segment. Also has a 1 inch lowering block. A lot depends on where the springs are mounted so don't forget the eye height.
[Re: BigBlockGTS]
#2914136
04/23/21 10:00 PM
04/23/21 10:00 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
On a street car, I think the Cal tracs would be much more forgiving without the binding associated with ladder bars. Also a lot less to cut to get them in. If that matters to a person. My old pump gas Duster with ladder bars and coil overs(15.0 inch extended with 7.0 inches of travel with 300 Lbs. rated springs) with a diagonal link never bound up or did anything worth complaining about in my opinion I drove it on the street for over 3000 miles and put hundreds of passes on it, love it You need to keep in mind that I'm a drag racer and love going fast and quick, not looking for a Lincoln or Rolls Royce ride either That rascal would hook up in a mud puddle in a rain storm also AKA aside, I loved that set up
[Re: Cab_Burge]
#2914243
04/24/21 10:38 AM
04/24/21 10:38 AM
Posts: 4,068 Mo.
racerx
Mo.
On a street car, I think the Cal tracs would be much more forgiving without the binding associated with ladder bars. Also a lot less to cut to get them in. If that matters to a person. My old pump gas Duster with ladder bars and coil overs(15.0 inch extended with 7.0 inches of travel with 300 Lbs. rated springs) with a diagonal link never bound up or did anything worth complaining about in my opinion I drove it on the street for over 3000 miles and put hundreds of passes on it, love it You need to keep in mind that I'm a drag racer and love going fast and quick, not looking for a Lincoln or Rolls Royce ride either That rascal would hook up in a mud puddle in a rain storm also AKA aside, I loved that set up Cab.....what heims were you running with your ladder bar set-up on the streets solids/poly's?I always thought the solids will take a beating on sh!tty roads.
