Another question 'bout the 518 #2912110
04/19/21 09:03 PM
04/19/21 09:03 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Haven't had much time to check it out , but on a 68 coronet ... does the the 518 overdrive fit behind the engine without modifying the hump...waying my options here.. want to still with the OD.. thanks
Re: Another question 'bout the 518 [Re: 70Challengerse] #2912168
04/20/21 05:45 AM
04/20/21 05:45 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
You'll have interference at the torsion bar crosmember. Modify the crosmember and floor for clearance.
Angry white pureblood male
Re: Another question 'bout the 518 [Re: 70Challengerse] #2912208
04/20/21 09:54 AM
04/20/21 09:54 AM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
If your fab skills are lacking, US Car tool had/has a trans crossmember for e-bodies. They may also have something for b-bodies as well. If I remember it was pricey at like $250-300.
1972 Dodge Challenger
Re: Another question 'bout the 518 [Re: PLUM_72] #2912209
04/20/21 09:59 AM
04/20/21 09:59 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I recently read that in an E-body, you can fit a 518 without modifying the car. The large reinforcing "ribs" on the OD tail shaft need to be cut off. This provides the needed clearance. I would think a B-body has the same amount of tunnel / x-member clearance that an E-body does. An A-body will need vehicle mods.
Re: Another question 'bout the 518 [Re: burdar] #2912264
04/20/21 12:14 PM
04/20/21 12:14 PM
BDW Offline
BDW  Offline
Installed 518 in my E-body with no mods other than the new cross member, as mentioned.
I would think the B body would have same or more room.
Have a PDF of the details, pm me for a copy.
Everything you need to know here:
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Re: Another question 'bout the 518 [Re: BDW] #2912380
04/20/21 03:52 PM
04/20/21 03:52 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
70 and older B bodies don't have the same room in the trans tunnel as the E bodies, I believe the crossmember is farther back than on the E bodies. On 70 and older B bodies about the only OD auto trans that will fit without extensive modifications to the trans tunnel/crossmember area is the 700r4/4l60e transmissions, the 200-4R with work but because of more bulk in the rear of the transmission the trans tunnel/crossmember area needs more clearancing.
Re: Another question 'bout the 518 [Re: chargerbr549] #2912604
04/20/21 08:47 PM
04/20/21 08:47 PM
Thanks for the replies... tunnel room on the 68 was my concern, wasn't sure on the older ones. up
Re: Another question 'bout the 518 [Re: 70Challengerse] #2912661
04/20/21 10:12 PM
04/20/21 10:12 PM
GA
roadrunninMark Offline
GA
42RH (A-500) is a little smaller and a little shorter than the 518. You will have to build it up internally to handle the power but it may save you from modifying the car.
Re: Another question 'bout the 518 [Re: roadrunninMark] #2912681
04/20/21 10:38 PM
04/20/21 10:38 PM
problem is the OD section same size as a 518...and interchanges..but is there room ,,,,I have many of both...gonna check...
Re: Another question 'bout the 518 [Re: burdar] #2913005
04/21/21 04:35 PM
04/21/21 04:35 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
On my challenger I had to cut two notches in the tortion bar x member after cutting some of the tailshaft housing on the trans away. Made my own crossmember by cutting the belly out of the oe one and welding some 3/16 in its place in between the ears.
Re: Another question 'bout the 518 [Re: roadrunninMark] #2913008
04/21/21 04:37 PM
04/21/21 04:37 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
It is 3" or so shorter, but the overdrive housing is the same. May still help clearances though.
Re: Another question 'bout the 518 [Re: 70Challengerse] #2913140
04/21/21 08:19 PM
04/21/21 08:19 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I put one in my 68 Charger, JW Bell housing, as said x member & thin the upper torsion x member where it is in the hump, a little hammer work inside the hump, I still have the factory console ,converted the stock shifter to a cable works great
Re: Another question 'bout the 518 [Re: CSK] #2913234
04/21/21 11:33 PM
04/21/21 11:33 PM
GA
GA
Yes, the OD housing is what gets trimmed, you will have to fit it up and see on a 42RH but here are 2 pics of the 518 where the areas get trimmed...
