Progression ignition distributor #2911628
04/18/21 01:27 PM
04/18/21 01:27 PM
Md.
carnut68 Online content OP
carnut68  Online Content OP
Md.
I know a few on the board have posted using them. How are they working out? Are they worth the $$? They seem simple enough.
America First!
Re: Progression ignition distributor [Re: carnut68] #2911636
04/18/21 01:42 PM
04/18/21 01:42 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I only have a few thousand miles on mine, so can't speak to longevity.
Tuning is a breeze, I never would have taken the time to get my curve as good as it is now. Changing around at the track, then tossing a street tune back in it takes seconds.
I noticed on my deal, less bouncing around at low rpm, more steady high rpms.
FYI uses a GM points style caps, or aftermarket like Accel or Mallory, which are speced to the GM size.
I would buy one again in a heartbeat.
Re: Progression ignition distributor [Re: 65Fury440] #2911662
04/18/21 03:52 PM
04/18/21 03:52 PM
Md.
Md.
I believe per their instructions it also eliminates the msd box?
America First!
Re: Progression ignition distributor [Re: carnut68] #2912107
04/19/21 09:02 PM
04/19/21 09:02 PM
Louisiana
BiomedTechGuy Offline
Louisiana
I'm really looking forward to getting one. It's the ignition I've always thought would be ideal for carb runners vs EFI, EFI having many of the advantages that come with the Progression Ignition.
I'm curious how the "small cap" Progression distributor fits with TF 270s
Re: Progression ignition distributor [Re: carnut68] #2912637
04/20/21 09:41 PM
04/20/21 09:41 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Yes the module is in the base.
