Anyone work around a truck 8hp70 oil cooler?
#2911368
04/17/21 03:58 PM
04/17/21 03:58 PM
Posts: 2,256 IL
furious70
IL
Only have photos, haven't seen in person. Is the oil cooler really in the way requiring additional tunnel work? Does anyone know if it can be remote mounted? Car vs truck pictured
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Anyone work around a truck 8hp70 oil cooler?
[Re: furious70]
#2911441
04/17/21 08:58 PM
04/17/21 08:58 PM
Posts: 1,408 Central Pa
moparjim79
Central Pa
Judging by pics posted, I would almost guarantee that the coolers are a bolt on deal, but there is a sensor looking thingy directly behind the cooler in between the mount ears that has me perplexed without seeing in person. I'm not thinking they are going to make 2 versions of that trans for cars and a different for trucks because of costs, but I've been wrong before.
Edit: after looking at a few on the web, it looks like the truck trans body is slightly different at the cooler location....
[Re: moparjim79]
#2911911
04/19/21 12:03 PM
04/19/21 12:03 PM
Posts: 1,552 Michigan
Kiddart
On line google search looks like there are some companies making fittings for bypass and remote pump. but not sure how tall or what the standoff is from the trans. worth doing the search to see what's out there, I do not know anyone who has done it.
Thank you Kiddart
[Re: Kiddart]
#2911917
04/19/21 12:37 PM
04/19/21 12:37 PM
Posts: 2,949 GA
roadrunninMark
GA
Hi Furious, I am seeing that the box could be a fluid heater, not a cooler. They were talking about that over on FB. Sound German Automotive supposedly sells a "heater bypass block" for them and then you can run lines to the radiator for a cooler.
[Re: roadrunninMark]
#2912116
04/19/21 09:11 PM
04/19/21 09:11 PM
Posts: 2,256 IL
furious70
IL
A heater, I wouldn't have thought that! I need to call Russel up and talk to him I guess.
[Re: furious70]
#2912376
04/20/21 03:41 PM
04/20/21 03:41 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I think we should call it a transmission temperature stabilizer, it heats the trans when it's cold and cools it when hot.
