Powermaster AD230 Alt #2911669
04/18/21 04:27 PM
04/18/21 04:27 PM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
How do you mount the Powermaster 165amp AD230 style alternators? Powermaster says this a Chrysler upgrade alternator in their literature. The mounting ears of the alternator don't look like they will mate up to typical Chrysler brackets. Wondering if the AR Engineering Denso brackets would work for this alternator. The alternator in question is linked below:
https://www.summitracing.com/parts/pwm-8-58529-120#overview
Thanks!
1972 Dodge Challenger
Re: Powermaster AD230 Alt [Re: PLUM_72] #2911769
04/18/21 09:08 PM
04/18/21 09:08 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I installed the 48529 using my stock 340 brackets. I did have to made spacers with the stock brackets to get the alternator moved forward away from the head/valve cover. I also had to find longer mounting bolts due to the spacers.
