2013 and up CARAVAN / T&C #2910867
04/16/21 10:26 AM
04/16/21 10:26 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Looking at one in that year range, The good, bad and the ugly please. What to stay away from and so on.
Aaaaaand go!
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 2013 and up CARAVAN / T&C [Re: Magnumguy] #2911027
04/16/21 05:53 PM
04/16/21 05:53 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Check the corners of the hood for rust bubbles. Very common.
Re: 2013 and up CARAVAN / T&C [Re: Magnumguy] #2911045
04/16/21 07:00 PM
04/16/21 07:00 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Blind spot modules. Cylinder head (3.6). There’s more, but retirement has filtered out my give a d @ mm memory.
Re: 2013 and up CARAVAN / T&C [Re: Magnumguy] #2911549
04/18/21 09:55 AM
04/18/21 09:55 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
We have a 2014 T&C. 125000+ no issues yet...
Re: 2013 and up CARAVAN / T&C [Re: sportfury70] #2911657
04/18/21 03:12 PM
04/18/21 03:12 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
wifes 2012 t&c 261,000 miles spark plugs,air filter,oil changes,alot of brakes&rotors,great vechile.
Re: 2013 and up CARAVAN / T&C [Re: Leigh] #2912188
04/20/21 08:02 AM
04/20/21 08:02 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
What year “Stow ‘n Go” seat equipped Chrysler van has the least problem areas?
Would the aftermarket warranty companies have data on which model year automobiles were least expensive to keep in running condition?
Re: 2013 and up CARAVAN / T&C [Re: 360view] #2912743
04/21/21 07:29 AM
04/21/21 07:29 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Buy the newest and lowest mileage one you can afford. Heated seats, steering wheel & GPS are a must
They are pretty good vehicles 2016 and later, many issues before 2016. Oil cooler cracking, body modules, cyl head problems, a hood corner corrosion issue that went away after 2016
Look for an R/T, GT or a fully optioned SXT, Avoid the ones with the actual ac unit in the back [separate controls on the lower center dash]
The R/T and GT ride better than the others.
The 2019 is way better than the 2016s
2020's are scarce.
You will find most used minivans are former rental vehicles and are very clean - the non rentals get more abuse, wear and tear.
Later ones came with Michelin tires that will last at least 50,000 miles.
There are web forums
Re: 2013 and up CARAVAN / T&C [Re: ThermoQuad] #2912781
04/21/21 09:20 AM
04/21/21 09:20 AM
S.E.Ohio
S.E.Ohio
Thanks y'all. We're looking at a 2017 w/97,000 miles on it, looks really clean.
