Hurst Ram Rod shifter #2910545
04/15/21 04:18 PM
04/15/21 04:18 PM
Rescue CA.
joes68340s Offline OP
Rescue CA.
Does anybody have experience with adjusting the ram rod shifter.
Re: Hurst Ram Rod shifter [Re: joes68340s] #2910572
04/15/21 05:11 PM
04/15/21 05:11 PM
I drove one car with one in it, never again tsk What a pain on the street and track down
Same thing on the Mr. Gasket shifter like it down
Trying to get it into 1st gear after a burn out and having to back up after the burn out was a real pain, no fun at all whiney
Give me the good old Competition Plus every day up
twocents
Re: Hurst Ram Rod shifter [Re: joes68340s] #2910573
04/15/21 05:14 PM
04/15/21 05:14 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
If I recall, you put shifter in Neutral, place an alignment pin through the shifter body and adjust the rods accordingly (trans levers in neutral). Then the hard stops, once your are able to actuate the gears. What issues are you having?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hurst Ram Rod shifter [Re: W.I.N. Racing] #2910597
04/15/21 05:58 PM
04/15/21 05:58 PM
Rescue CA.
Rescue CA.
I have rods adjusted not sure what the t handle to engage first should be. Sometimes it doesn't seem to engage first. Just wondering if anyone knows the procedure for T handle.
Re: Hurst Ram Rod shifter [Re: joes68340s] #2910599
04/15/21 06:08 PM
04/15/21 06:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The T handle rod has a threaded bottom end with a locknut on it. I've never had to adjust it but I imagine that's where you would do any adjustment.
I've had one of those in my RR. In my opinion its a PITA shifter. "race only" as far as I'm concerned. Not only is downshifting a PITA, but if its in a street car its a real nuisance getting into first at any stop. Drive any significant distance in stop-and-go traffic and in a half hour you'll have blisters on your fingers from pulling that T handle up!
Re: Hurst Ram Rod shifter [Re: Stanton] #2910602
04/15/21 06:14 PM
04/15/21 06:14 PM
Rescue CA.
Rescue CA.
Its in a Drag car only.
Re: Hurst Ram Rod shifter [Re: joes68340s] #2910699
04/15/21 09:05 PM
04/15/21 09:05 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Love that shifter, I never had an issue driving on the street.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Hurst Ram Rod shifter [Re: davesmopars] #2910704
04/15/21 09:13 PM
04/15/21 09:13 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Are y'all talking about the Verti-gates or the Lightning Rods? I drove many a Verti-gate back in the day and they took some getting used too.... work
Re: Hurst Ram Rod shifter [Re: bobby66] #2910720
04/15/21 10:01 PM
04/15/21 10:01 PM
Those are three different shifters, the ram Rod and Verti Gate are similar, the Lightening rods was completely different, 4 shift sticks like the Lenco shifter had scope
Re: Hurst Ram Rod shifter [Re: Cab_Burge] #2910765
04/16/21 01:21 AM
04/16/21 01:21 AM
Washington
madscientist Offline
Washington
The Ram Rod is the best inline shifter out there for OE style gear boxes. I’m not sure how anyone can’t figure out how to downshift one. I’ve got countless miles on the street with one. And I now have one for this car.
Re: Hurst Ram Rod shifter [Re: madscientist] #2910820
04/16/21 09:01 AM
04/16/21 09:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Nobody said "can't" !!!
Re: Hurst Ram Rod shifter [Re: Stanton] #2910860
04/16/21 10:14 AM
04/16/21 10:14 AM
my own world
theraif Offline
theraif  Offline
my own world
may help shruggy
Re: Hurst Ram Rod shifter [Re: davesmopars] #2910894
04/16/21 11:06 AM
04/16/21 11:06 AM
s.d.
K
kermit1 Offline
kermit1  Offline
K
s.d.
yea i love it too !! a little noisy but worth it
Re: Hurst Ram Rod shifter [Re: kermit1] #2911105
04/16/21 09:52 PM
04/16/21 09:52 PM
birdtracker Offline
birdtracker  Offline
this thread brings back alot of memories and realizations of how wild and crazy I was back in the late 80's and early 90's. I had a 68 GTX 440 4speed car that I bought in 1986 when I got out of the service. The car was absolutely wicked fast.I put a Hurst inline shifter in it for about 4 years. I absolutely loved it. So much I took it out and cut 4 inches out of both the main handle and the thin rod for up and down. I could power shift it and never use the clutch. I ended up putting an air shock on the right rear so the car would go straight launching it.
Mine had the alignment tool to center everything. Enjoy your 4 speed. Birdtracker
Re: Hurst Ram Rod shifter [Re: birdtracker] #2911125
04/16/21 10:27 PM
04/16/21 10:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
You must have arms like an ape to reach it !!
Re: Hurst Ram Rod shifter [Re: Stanton] #2911256
04/17/21 10:26 AM
04/17/21 10:26 AM
Washington
Washington
Originally Posted by Stanton
Quote
No one in this thread said it, but I’ve heard it so many times I can’t count them all. Crap like you can’t downshift from third to second with an inline shifter and other assorted nonsense.
I should have clarified that after I typed it. Another one I’ve heard is it takes two hands to get it in reverse. I never found that to be true. Who knows what these guys are doing...maybe they aren’t adjusted correctly, or with a Ram Rod they don’t have the correct spring for reverse. I’ve never had to use two hands.
Re: Hurst Ram Rod shifter [Re: Cab_Burge] #2911325
04/17/21 12:51 PM
04/17/21 12:51 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
[quote=Cab_Burge]I drove one car with one in it, never again tsk What a pain on the street and track down
twocents
Ran both of those on the street and strip loved them both. Even used the old 3sp shifter with a separate reverse lever.
Real Men shift for themselves
Re: Hurst Ram Rod shifter [Re: davesmopars] #2911933
04/19/21 01:19 PM
04/19/21 01:19 PM
mn.
taxidermy man Offline
mn.
Me neither.
Re: Hurst Ram Rod shifter [Re: davesmopars] #2911934
04/19/21 01:21 PM
04/19/21 01:21 PM
mn.
mn.
Me neither
Re: Hurst Ram Rod shifter [Re: taxidermy man] #2912295
04/20/21 01:17 PM
04/20/21 01:17 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
I have an order in for a Long inline 4 speed shifter for my Duster. They are G-Force transmission, pretty well made piece. Have run a Hurst inline for years. Wanted a modern version of the shifter.
