Heads are done. A couple questions... #2910284
04/14/21 10:11 PM
04/14/21 10:11 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I got the Eddy heads back from porting today. This is the first time I've had this kind of work done and wanted to know if this is common.
As a machinist, I'm well versed in the mechanics of machining dissimilar metals in a single assembly. However, it strikes me as odd that the little thin chunkies of aluminum would be left hanging near the valve guides. It makes me want to pull the valves and clean it up by hand. Granted, it's tiny thin flakes of aluminum that are unlikely to cause damage but I'll be left wondering if they're flaking off as the engine runs.
The spark plug holes look pretty rough, too. I know that threads mean a tapered end will have highs and lows based upon the depth of the thread at each point. I'll shoot some plugs in them and see which holes need attention.
I also noticed there are little pockets in the port roof just in front of the guides. At first glance it looked like he broke through to the spring seats but closer examination shows it to be little pockets left over from the original casting.True to mass production casting, the little pockets vary from port to port.
It seems his program didn't do much to the intake port roof but it might not have been necessary and breaking through would be listed as Bad Thing.
The chambers look pretty nice other than the plug bosses. I haven't popped out a valve to inspect the seat work, nor have I stuffed an endoscope in there.
What are your impressions of the job done by this one crappy pic of one random port?
- Stu Harmon
Re: Heads are done. A couple questions... [Re: feets] #2910304
04/14/21 11:07 PM
04/14/21 11:07 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
That looks bad and if you ask me. It is poor workmanship.. I look them over real good.
Re: Heads are done. A couple questions... [Re: feets] #2910329
04/15/21 12:20 AM
04/15/21 12:20 AM
AndyF Online content
AndyF  Online Content
That is the downside of a CNC program. Sometimes the casting variance will move features around but the program is the program. The more aggressive the CNC program the more likely you run into thin spots. I had Modern do a set of heads for me years ago and their program was so aggressive that the heads ended up needing to be repaired. On the flip side, the Trick Flow programs seem to be conservative enough that I've never seen any problems with any of their heads which have come in the shop. It just boils down to how aggressive the programmer was in removing material to make power. And of course, sometimes it is just bad luck. Even a conservative program can end badly if the casting is thin.
Re: Heads are done. A couple questions... [Re: AndyF] #2910332
04/15/21 12:32 AM
04/15/21 12:32 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I assume you'd blow them apart and clean them up.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: feets] #2910348
04/15/21 01:26 AM
04/15/21 01:26 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Typical of a CNC program.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Heads are done. A couple questions... [Re: feets] #2910359
04/15/21 01:49 AM
04/15/21 01:49 AM
Not me, I learned my lesson and now everything goes to Porter Racing Heads before it comes to me.
Re: Heads are done. A couple questions... [Re: AndyF] #2910380
04/15/21 06:18 AM
04/15/21 06:18 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yup. Take apart and run around the guides with a sanding cartridge. 60 to 80 grit
Put some dykim on the seats and run a valve to see the margin.
.050 wide is average
Re: Heads are done. A couple questions... [Re: AndyF] #2910400
04/15/21 08:28 AM
04/15/21 08:28 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
He suggested this vendor. I assumed they'd be viable when they came back to me. Didn't think I'd have to send them to a third party for finishing.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: feets] #2910439
04/15/21 10:46 AM
04/15/21 10:46 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Wait a minute? You had the heads ported and prepped by a shop and they sent them back to you with the advice to send them to another shop for "finishing"???
Re: Heads are done. A couple questions... [Re: feets] #2910441
04/15/21 10:50 AM
04/15/21 10:50 AM
New York
polyspheric Offline
polyspheric  Offline
New York
More variables:
1. how many passes are used to remove X amount of material (how many hours is the machine running)
2. what radius is the cutting head
Boffin Emeritus
Re: Heads are done. A couple questions... [Re: feets] #2910458
04/15/21 11:38 AM
04/15/21 11:38 AM
moparx Offline
moparx  Offline
as a machinist, i don't like what i see on that guide, CNC program or not.
those heads need taken apart and that mess touched up/fixed.
how many ports are like that ?
beer
Re: Heads are done. A couple questions... [Re: moparx] #2910462
04/15/21 11:49 AM
04/15/21 11:49 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yikes. Rather depressing if it wasn't checked and communicated before shipping out.
I understand the variances, but I wouldn't consider that ready to run.
Re: Heads are done. A couple questions... [Re: BigBlockGTS] #2910518
04/15/21 02:48 PM
04/15/21 02:48 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
No.
He sent them back with no invoice or suggestions after charging me 60% more than we discussed on the initial quote.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: polyspheric] #2910521
04/15/21 02:52 PM
04/15/21 02:52 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
More variables:
You missed something.
I am a machinist. Therefore, I know exactly what I'm seeing.
I see a distinct lack of second operations and/or hand work to finish. It's the type of work that doesn't leave my shop.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: moparx] #2910522
04/15/21 02:55 PM
04/15/21 02:55 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
beer
All ports are like that.
This is not what I expected to see after being told "around $750" and being charged $1233.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: feets] #2910550
04/15/21 04:27 PM
04/15/21 04:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Did you get a flowsheet?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Heads are done. A couple questions... [Re: feets] #2910551
04/15/21 04:27 PM
04/15/21 04:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
If you can get them to Katy Tx, take them apart & bring 2 retainers with locks & one each valves & I will fix them & give you some flow #'s off of my toy Super Flow bench,, No charge !!! & to be VERY clear I almost did not want to make this post because I do NOT want to take work away from Dwayne Porter, he is the BEST choice
Re: Heads are done. A couple questions... [Re: CSK] #2910567
04/15/21 05:00 PM
04/15/21 05:00 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Sorry to jump back in but regardless of Feets ultimate direction, that is a stand up offer csk!! Thanks for being on the board.
Re: Heads are done. A couple questions... [Re: pittsburghracer] #2910569
04/15/21 05:00 PM
04/15/21 05:00 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I didn't even get a thank you.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: CSK] #2910570
04/15/21 05:02 PM
04/15/21 05:02 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I appreciate the offer CSK.
I'll send you a message.
- Stu Harmon
