Re: 1991 Cummins 3-Speed Question
[Re: 500ciDuster]
#2909755
04/13/21 12:36 PM
04/13/21 12:36 PM
Posts: 5,825 ohio
ruderunner
ohio
Probably but, the early lockup converters won't hold the torque. Later diesel lockup converters might not fit in the bell, if they're even compatible with the shafts.
Most guys spend the money on a good tight low stall converter in those applications.
Angry white pureblood male
[Re: 500ciDuster]
#2910003
04/14/21 08:54 AM
04/14/21 08:54 AM
Guitar Jones
It can be done but it isn't just a bolt in. The diesel lockup converter is thicker by about 1.5" which means the converter sticks out from the bellhousing face about an inch. You need the 2 nd gen trans adapter and starter. The starter hits the frame rail so clearancing is needed there. The second gen adapter is approx. 1.25 longer to fit the converter so the transmission crossmember needs to move rearwards the same amount and shorten the drive shaft. For all that work you might as well swap to a 47RH and get the overdrive as well. You may need a crossmember from an O/D equipped truck but it doesn't have to be a diesel.
[Re: 500ciDuster]
#2910193
04/14/21 05:21 PM
04/14/21 05:21 PM
Posts: 5,825 ohio
ruderunner
ohio
Correct, no lockup in the 89 to 93 trucks
[Re: 500ciDuster]
#2910378
04/15/21 06:13 AM
04/15/21 06:13 AM
Guitar Jones
The 47RH was a two year only deal, 94-95. You can however convert a 91.5-93 non lockup diesel 518/46RH to lockup with the correct input shaft, reaction shaft (or support) and the lockup valve body. Here is my write up on another site. Turn a non lockup into a lockup
