fuel regulator #2909309
04/11/21 11:01 PM
04/11/21 11:01 PM
BigFish69 Offline OP
what is a good fuel regulator to support 800 hp motor dead head style none return
thanks
Re: fuel regulator [Re: BigFish69] #2909546
04/12/21 06:09 PM
04/12/21 06:09 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Aeromotive 13201 is good to 750hp, don’t know if they make one that will handle 800hp.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: fuel regulator [Re: BigFish69] #2909580
04/12/21 08:00 PM
04/12/21 08:00 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: fuel regulator [Re: GomangoCuda] #2909792
04/13/21 01:44 PM
04/13/21 01:44 PM
NC
440Jim Offline
440Jim  Offline
NC
I bought one of Robb's dual mode regulators way back in the early 2000's.
I ran it a couple years in dead-head mode in my other car before switching to injected alcohol.
Well it sat in the box for years until I bought my Daytona and so I put it in this car. I decided to use it in return mode (plunger swap).
https://www.robbmcperformance.com/products/regulator_dm.html
Good to know he is still in business, I may buy a new diaphragm to have on the shelf for the future.
Re: fuel regulator [Re: BloFish] #2913779
04/23/21 08:59 AM
04/23/21 08:59 AM
an8sec70cuda Offline
This regulator will support over 800 hp. I had this regulator along w/ the little Aeromotive street rod pump on my car running 9.50s at 140 mph at 3800 lbs. Dead head system w/ -8 line.
CHIP
'06 GMC 2500HD LBZ Duramax
