fuel pump pushrod recommendations
#2909276
04/11/21 10:05 PM
04/11/21 10:05 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I have two engines to assemble in the next six months. What is the recommended fuel push rod to use. I recall some discussion on possible poor heat treating resulting in premature failure. Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: fuel pump pushrod recommendations
[Re: RoadRunner]
#2909279
04/11/21 10:07 PM
04/11/21 10:07 PM
Posts: 4,673 Wichita
GY3
Wichita
I have two engines to assemble in the next six months. What is the recommended fuel push rod to use. I recall some discussion on possible poor heat treating resulting in premature failure. Thanks. The Howards one works great if you're using a billet roller type cam.
[Re: GY3]
#2909386
04/12/21 09:37 AM
04/12/21 09:37 AM
RoadRunner
I have two engines to assemble in the next six months. What is the recommended fuel push rod to use. I recall some discussion on possible poor heat treating resulting in premature failure. Thanks. The Howards one works great if you're using a billet roller type cam. Not sure if I will go roller or flat tappet. One engine will be leaning more towards stock build (440 and auto) while I am thinking of going with a bit wilder 383 build for my 68 Road Runner. I am thinking of stroker kit (432 most likely), aluminum Edelbrock heads, headers, etc. So ay go with a roller cam here.
[Re: RoadRunner]
#2909408
04/12/21 10:25 AM
04/12/21 10:25 AM
Posts: 13,587 md
mopars4ever
md
