Carb Bolt Question #2908971
04/11/21 09:42 AM
04/11/21 09:42 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. Does anyone have an idea if a 1970 B body 440 carter carb has bolts or studs? What kind of gasket do you use?
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Carb Bolt Question [Re: GTXKARL] #2909022
04/11/21 11:40 AM
04/11/21 11:40 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
should be bolts. mopar had a grade five 5/16"-18x 1 1/8" bolt that some refer to as a "spider" hex head. i wouldn't get too lost in the gasket as long as it's square bore with 1 11/16' holes. i prefer an insulator gasket which isn't OEM.
