Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Build share [Re: Al_Alguire] #2853350
11/30/20 02:03 PM
11/30/20 02:03 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Looking good Sean. Starting to look like a finished car!
Re: Build share [Re: HardcoreB] #2853452
11/30/20 04:48 PM
11/30/20 04:48 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Originally Posted by HardcoreB
Prototype horn button cover from a yogurt lid and wiring clean-up...added trans temp.
Man, that looks awesome! What coating did you use on the floor pans?
Re: Build share [Re: mopowers] #2853527
11/30/20 07:53 PM
11/30/20 07:53 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Really coming along nice, Sean! Really eager to see it move under it’s own power.
Randy
Re: Build share [Re: Dartin] #2853562
11/30/20 09:14 PM
11/30/20 09:14 PM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
!!!Thanks again guys!!!...I'm surprised the floor paint is getting complements because IMO it's a 3-footer (no pun intended) All I did was figure out what roller to use and how many passes it took before shedding lint. It's Armor-all hammered black. However that took A LONG TIME to figure out stripping and sanding after each failure. You gotta know some 6-year old kid will come along later and nail it first try? It's frustrating to think about... short of anyone exaggerating that it looks 'great' I have a long string of expletives waiting in response lol.
Re: Build share [Re: Al_Alguire] #2853563
11/30/20 09:16 PM
11/30/20 09:16 PM
Shelby Twp. Mi
Shelby Twp. Mi
Originally Posted by Al_Alguire
Gonna throw some carpet mats in there to protect those purdy floors?? Looking great maybe one day Ill get to see it in person.
I have thought about it... work
Re: Build share [Re: HardcoreB] #2853637
12/01/20 12:29 AM
12/01/20 12:29 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Have to tried any testing with the scoop your using, with and without? Ever tried a cowl scoop. I have been contemplating a scoop for my t ram set up. Curious to what works and what don't. Thanks
Re: Build share [Re: mopar dave] #2853763
12/01/20 12:31 PM
12/01/20 12:31 PM
Shelby Twp. Mi
Shelby Twp. Mi
There are so many good discussions about hood scoops that are worth referencing with one more recently done in this Forum. And yes I have tested with many different styles and cars. I have found generally, fwd facing are the most forgiving to execute some performance benefit. In the end you have to try things and figure out what works with A/F data ideally. The trouble is that most people will say WHY something worked or didnt and be wrong therebty misleading others. Put the bottom of the scoop opening ABOVE the string-line run from the roof to the front of the hood and choose a scoop that has about 3.5" room to the airhorn ( s) Sidebar Q for Alguire if you're still here...care to hazard a guess how much more fluid in quarts than "full cold" I should start the trans level at? There's 4 total in it now (full level cold) and I'm using your old 8" ATI conv which didn't loose any in shipping.
Re: Build share [Re: HardcoreB] #2853777
12/01/20 01:18 PM
12/01/20 01:18 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
If it were me 4qts is plenty to fire it up with. As for total capacity will depend on what pan cooler and lines you use. Considering there is likely 1.5ish in the converter you wont need a ton more for sure. Here is what ATI has to say. As for ultimate level I never run them completely full in the shop as you will likely not get enough heat in it to get an accurate read. Although engaging the brake will help put some heat in it.
http://www.atiracing.com/instructions/Trans-Converter-Installation.pdf
Re: Build share [Re: Al_Alguire] #2908443
04/09/21 04:07 PM
04/09/21 04:07 PM
Shelby Twp. Mi
Shelby Twp. Mi
More updates...old trunk and tubs
Re: Build share [Re: HardcoreB] #2908445
04/09/21 04:07 PM
04/09/21 04:07 PM
Shelby Twp. Mi
Shelby Twp. Mi
new
Re: Build share [Re: HardcoreB] #2908447
04/09/21 04:09 PM
04/09/21 04:09 PM
Shelby Twp. Mi
Shelby Twp. Mi
pan
Re: Build share [Re: HardcoreB] #2908448
04/09/21 04:10 PM
04/09/21 04:10 PM
Shelby Twp. Mi
Shelby Twp. Mi
new tubs fixxed alot of issues: gaps and spliced panels
Re: Build share [Re: HardcoreB] #2908449
04/09/21 04:12 PM
04/09/21 04:12 PM
Shelby Twp. Mi
Shelby Twp. Mi
New sill plates cover more area and better gaps
Re: Build share [Re: HardcoreB] #2908450
04/09/21 04:15 PM
04/09/21 04:15 PM
Shelby Twp. Mi
Shelby Twp. Mi
cleaned up all wheel well area removing unnecessary metal
Re: Build share [Re: HardcoreB] #2908502
04/09/21 07:47 PM
04/09/21 07:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Looking good. Lets go racin.
Doug
Re: Build share [Re: HardcoreB] #2908743
04/10/21 02:01 PM
04/10/21 02:01 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Wow , that looks great . Nice work . Thanks for posting this . Gives others great ideas . Gary
Re: Build share [Re: Gabby63] #2912191
04/20/21 08:20 AM
04/20/21 08:20 AM
Shelby Twp. Mi
Shelby Twp. Mi
Package tray area. 1 piece replaced 3.
Re: Build share [Re: HardcoreB] #2912479
04/20/21 06:08 PM
04/20/21 06:08 PM
Dartin Offline
Dartin  Offline
As eager as I am to see you get this car wrapped up and racing, I’m glad you put the extra effort in to fixing some of the poor fitting tin work that you had “the other guy” make. The rest of the work is far too nice. It’s a shame you didn’t get what you paid for.
Re: Build share [Re: Dartin] #2912780
04/21/21 09:16 AM
04/21/21 09:16 AM
Shelby Twp. Mi
Shelby Twp. Mi
Thanks again Randy! and fellas. I just had some updates and I figured I'd add with old/new work...still moving along. As-of last night, I have a cardboard template of hopefully THE LAST two pieces of tin.
Re: Build share [Re: HardcoreB] #2913927
04/23/21 01:50 PM
04/23/21 01:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
looks great !!
....BAD A$$ STREET CAR.....
