Any tricks on getting squirter check valves out of a center #2908390
04/09/21 12:31 PM
04/09/21 12:31 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Without taking off the center carb off the engine?
Mine are gunked up from this crappy gas.
Want to get out to the local cruise tonight.
Re: Any tricks on getting squirter check valves out of a center [Re: Sammy] #2908392
04/09/21 12:38 PM
04/09/21 12:38 PM
Pull the squirter part off and if it is has a square check valve shoot some carb cleaner on top of it and let it sit a little while, do that again and try and use a small diameter wire to move it around to make it loosen so it will squirt scope
If it has a round check valve take the carb off first and go from there wrench shruggy
Re: Any tricks on getting squirter check valves out of a center [Re: Cab_Burge] #2908409
04/09/21 01:27 PM
04/09/21 01:27 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
It's a stock OE 6 barrel carb. No modifications.
Re: Any tricks on getting squirter check valves out of a center [Re: Sammy] #2908410
04/09/21 01:32 PM
04/09/21 01:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
A magnet might work.
Rich H.
Esse Quam Videri
Re: Any tricks on getting squirter check valves out of a center [Re: Cab_Burge] #2908492
04/09/21 07:12 PM
04/09/21 07:12 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I've used this method several times, just try to wiggle it around with a stiff wire or tiny screwdriver.
Now be careful about opening the throttle without the nozzle in place, it might shoot out and fall in the carb or engine!
You don't want to make more work for yourself!
