Ballast Resistor #2908183
04/08/21 09:14 PM
04/08/21 09:14 PM
Kentucky
dfsmopars Offline OP
Kentucky
‘85 truck. 318. Friend’s truck. Will not start after running a little bit. Ballast resistor is real hot. Resistor looks new. Can a door prong resistor be used in order to trouble shoot?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Ballast Resistor [Re: dfsmopars] #2908198
04/08/21 09:33 PM
04/08/21 09:33 PM
Andrewh Offline
Andrewh  Offline
ballast is bypassed during start.
so if it was the ballast you would expect it to start then die when you let off the key.
Re: Ballast Resistor [Re: Andrewh] #2908203
04/08/21 09:46 PM
04/08/21 09:46 PM
Kentucky
Kentucky
It’s getting super hot. Quickly. Plenty of fuel. Spark to and from distributor. New MSD Blaster coil. After truck sits for a little while it starts.
Re: Ballast Resistor [Re: dfsmopars] #2908219
04/08/21 10:57 PM
04/08/21 10:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ballast resisters get very hot that's why they are ceramic bodied.
Re: Ballast Resistor [Re: dfsmopars] #2908222
04/08/21 11:04 PM
04/08/21 11:04 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
You're loosing an electrical connection somewhere after system heats up. Connection can re-establish itself after cool down.
Possibles:
1) connection between ballast terminal spade & coil wire inside it.
2) Dist. pickup coil/leads: I sure had this happen to me few years back.
Cut-out on hwy., & after some cool down time started back up.
Occurred to me 2 times before I fixed it.
That's it for now.
Re: Ballast Resistor [Re: dfsmopars] #2908229
04/08/21 11:29 PM
04/08/21 11:29 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You lost me at "door prong resistor ". shruggy
Re: Ballast Resistor [Re: GomangoCuda] #2908304
04/09/21 05:18 AM
04/09/21 05:18 AM
Kentucky
Kentucky
Yea I can see that. blush
Four prong.
Re: Ballast Resistor [Re: dfsmopars] #2908348
04/09/21 09:51 AM
04/09/21 09:51 AM
VA
dragon slayer Offline
VA
What is the resistance on the ballast? So you added new coil and ballast get real hot. That means excessive current and possibly coil over heating. Need to check the wiring, and make sure the resistor meets the coil spec.
Re: Ballast Resistor [Re: dragon slayer] #2908429
04/09/21 02:40 PM
04/09/21 02:40 PM
GomangoCuda Offline
GomangoCuda  Offline
Exactly haha. What ignition ecu, what coil and what resistor? They are designed to work together and you may have disrupted the combination with the Blaster coil. Different coils can have very different primary resistance. What works best on a CD ignition is probably very wrong on an Inductive ignition. If the total resistance of the coil and ballast resistor is too low the ECU life may suffer. If the ballast resistance is too low for the coil then coil life could suffer. If the total resistance of the coil and ballast is too high then spark strength will suffer. If everything works together they will have a very long life. Things tend to go sideways If you upset that ballance by changing a part to something inappropriate.
Re: Ballast Resistor [Re: Andrewh] #2908439
04/09/21 03:17 PM
04/09/21 03:17 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Not necessarily true. I had a ballast resistor go bad years ago on a '71 Charger & it would start & run just fine, then just cut-out at very inconsistent intervals.
OP, start it & then get out & wiggle the wires connecting to the BR - if it sparks & shuts off, then it's the BR.
Re: Ballast Resistor [Re: Sunroofcuda] #2908441
04/09/21 03:50 PM
04/09/21 03:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had one break!
Re: Ballast Resistor [Re: dfsmopars] #2908451
04/09/21 04:17 PM
04/09/21 04:17 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Does it have spark when it will not start???
Re: Ballast Resistor [Re: NITROUSN] #2908453
04/09/21 04:27 PM
04/09/21 04:27 PM
Kentucky
Kentucky
It does have spark when it will not start.
Re: Ballast Resistor [Re: dfsmopars] #2908517
04/09/21 08:52 PM
04/09/21 08:52 PM
N
N
So if there is spark to the plugs you are either starved of fuel or flooded.
Re: Ballast Resistor [Re: Sunroofcuda] #2908549
04/09/21 10:49 PM
04/09/21 10:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The point was that the ballast is not used during start. So if it won;t start it's probably not the ballast.
OP later does say that there is spark when it won't start so the issue probably isn't ignition related, unless the timing is way off. Jumped timing chain?
Re: Ballast Resistor [Re: Sniper] #2908565
04/09/21 11:27 PM
04/09/21 11:27 PM
Kentucky
Kentucky
I think I got it a little closer tonight. I swapped out the coil with one with higher resistance. About where I would expect it around 1.5-2.0 ohms. Then the timing that was at about 5 degrees BTDC, I moved it to about 3-4 degrees ATDC. Then I noticed the starter motor was dragging just a tad after attempts to start the engine. I put a charger on the battery and it helped some. I at least could sort of repeat the failure and the ignition. It still has its moments where it does not want to start. So the next question I have is this- can the starter become weaker as it warms up? I can pour a cap full of fuel in the carb and it does not help the starting. I don’t think it is flooding because it is a 2V carb that I took off the shelf and it ran well when I put it on there. There is plenty of bad wiring under the hood. Some wiring has lost its insulation. So that stuff has to be cleaned up as well.
About the BR, should I be able to hold it in my hand while the truck is running without feeling like I’m going to get burned.
I think there are numerous issues working in according. It’s not there but I sa things tonight that encourages me that it will get there.
Once it starts it is slick, smooth and responsive.
Re: Ballast Resistor [Re: dfsmopars] #2908584
04/10/21 12:37 AM
04/10/21 12:37 AM
5thAve Offline
5thAve  Offline
No, ballast resistor is hot to the touch you wouldn't want to hold it. Like others have already said ballast resistor is bypassed during starting. If it's bad it will have no problem starting but will stall when you let go of they key. If it won't start at all its something else.
Right now my truck is hard starting and if you do get it running it dies pretty quickly. I got it down to a bad fuel pump.
Re: Ballast Resistor [Re: 5thAve] #2908637
04/10/21 08:39 AM
04/10/21 08:39 AM
VA
VA
Description of the issue and symptoms need to be more clear otherwise folks starting reading into your issue and then down the rabbit hole. I reread your first post. First, you start the truck and it is running. Does it shut off on its own or do you turn it off? Hard starting of a hot engine can be several issues including vapor lock of the fuel lines.
Yes you should start with a know good and fully charge battery. Good fuel with a know good fuel pump. Good starter. If it cranks over easy hot, and it does have spark (continuous when cranking) it most likely is a fuel problem when hot as long as you know it sparks not just on the coil wire, but at a plug wire too.
The overly hot ballast can still we an issue with a coil out of spec to the ballast.
Re: Ballast Resistor [Re: dragon slayer] #2908640
04/10/21 09:03 AM
04/10/21 09:03 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
A hot coil will mimic vaporlock. Shut it down after a drive and it won't start, let it cool and away you go again.
1969 Hemi Roadrunner 2nd owner
Re: Ballast Resistor [Re: 69hemibeep] #2908704
04/10/21 11:35 AM
04/10/21 11:35 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Timing should be about 18* btdc with the vacuum advance disconnected. To much advance will make it turn over very slowly.
