Re: 440” w8 on the dyno
[Re: Red440]
#2907687
04/07/21 01:24 PM
04/07/21 01:24 PM
Posts: 16,932 NC
440Jim
NC
[Re: 440Jim]
#2907777
04/07/21 05:12 PM
04/07/21 05:12 PM
Posts: 1,784 PA
W5DART66
PA
[Re: mopar dave]
#2907786
04/07/21 05:40 PM
04/07/21 05:40 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Those 440w8 combo's are very impressive in the power they can make. I know of another 440w8 deal that just went right under 900hp. The w8 head must be one hell of a great head. Why can't someone make a big block wedge head that works as well as the w8's? They do.
[Re: mopar dave]
#2907810
04/07/21 07:21 PM
04/07/21 07:21 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Those 440w8 combo's are very impressive in the power they can make. I know of another 440w8 deal that just went right under 900hp. The w8 head must be one hell of a great head. Why can't someone make a big block wedge head that works as well as the w8's? The supply for current BBM wedge heads is present, however the demand to use them or over-the-top R&D isn’t there IMO. It cost time/money. As with any head or motor combo, they’re only as good as their development, and most importantly only as good as the “human” behind it all making it happen. Brett is definitely making it happen and giving SBM guys options to go fast!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#2907825
04/07/21 08:01 PM
04/07/21 08:01 PM
Posts: 6,150 Melbourne , Australia
LA360
And they've not done any new castings since the Pro Stock Trucks days either.
As Wes eluded to, most of the BBM guys aren't interested in anything other than the stuff that is available. How many engines do you see with Predator heads at the track?
Alan Jones
[Re: LA360]
#2907970
04/08/21 11:27 AM
04/08/21 11:27 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
As Wes eluded to, most of the BBM guys aren't interested in anything other than the stuff that is available. How many engines do you see with Predator heads at the track? Back here in Ohio a LOT of them are Predator headed, and plenty fast. But still apples to oranges comparison.
[Re: W5DART66]
#2908036
04/08/21 02:23 PM
04/08/21 02:23 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Impressive! Always figured an engine like that would be very involved maintenance-wise. Those things sure scream!
[Re: W5DART66]
#2908083
04/08/21 04:42 PM
04/08/21 04:42 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I am not going to say no maintenance but way less than you would think.
Has Jesel keyway lifters and small light springs light titanium valves.
The upfront price for this type parts is high but return on investment much better.
I can do 950-1000 HP W8 deal that will go 100s of passes with next to 0 maintenance.
My 880HP 411 w8 engine built for engine masters in 2011 has 150+ dyno pulls 100s of passes in my car 8.80s at 150mph
Then it went in Brad Bowers dart for drag week NA small block (we won😉)
She is still together 10 years same rings and bearings.
I did change springs for drag week. 🤪 Very impressive. If I ever win the lottery I'll have you build me one to play with in the heads up street classes around here.
[Re: Al_Alguire]
#2908110
04/08/21 06:23 PM
04/08/21 06:23 PM
LA360
As Wes eluded to, most of the BBM guys aren't interested in anything other than the stuff that is available. How many engines do you see with Predator heads at the track? Back here in Ohio a LOT of them are Predator headed, and plenty fast. But still apples to oranges comparison. I was trying to think of a BBM head that was decent and fit on a factory bore space block, I probably should have used a B1 head in my example instead. I shied away from it, because that casting hasn't really been changed since the early 90's, even the PSO version.
Alan Jones
[Re: W5DART66]
#2908254
04/09/21 01:25 AM
04/09/21 01:25 AM
Posts: 263 CA, USA
JcodeCharger
CA, USA
I did change springs for drag week. 🤪 Brett, I would like to buy a set of W8’s from you. How do I get ahold of you?
68 twin turbo Dart 8.19 so far 70 Swinger 360 69 Roadrunner 383 4 speed 69 Mod Top Satellite 383 auto 69.5 A12 Super Bee 4 speed 70 T/A Challenger 70 FC7 Duster 340 4 speed 70 FJ5 Superbird 68 Hemi 4 speed Roadrunner 71 Duster W2 340
