Re: 213 big block heads-any advantage?
[Re: 446acuda]
#290750
04/17/09 11:53 AM
04/17/09 11:53 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Don't these take a special water pump that bolts to the head?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: polkat]
#290752
04/17/09 12:28 PM
04/17/09 12:28 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Found a set of 3751213 heads in a friends back yard. As I understand it, these were called 'Motor Home' heads and were supposed to have better cooling particularly around the spark plugs. Anyone know the chamber size, and do they have hardened seats? Are they worth working on or am I just wasting my time?
I'll pick B Jack ... wasting time
[Re: 440FISH]
#290753
04/17/09 12:29 PM
04/17/09 12:29 PM
JohnRR
They are 452's with cooling hole in head near the sparkplug (steam hole), smaller 5/8" spark plug, different type of exhaust valve to handle the heat, and also special retainers on the exhaust spring.
I have 452's with those passages and plugs , they are not marked 213 ???
[Re: polkat]
#290755
04/17/09 03:39 PM
04/17/09 03:39 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I had a set of 213s and they looked like any other passenger car BB head.
[Re: polkat]
#290756
04/17/09 03:42 PM
04/17/09 03:42 PM
JohnRR
These don't have the water pump bolted to them, and I see no blockoff plates, but they are 213's. So just considering them as heads, I can consider them just like 452's?
yes
[Re: polkat]
#290759
04/19/09 11:50 PM
04/19/09 11:50 PM
JohnRR
So do the 213's have hardened seats?
NO , the casting is flame hardened , do a valve job and or intall larger valves and the hardened area is pretty much history .
[Re: RainBoKatchr]
#290761
04/20/09 06:45 PM
04/20/09 06:45 PM
JohnRR
So on the 213 heads I have that have 17K original miles on them, if I DON'T do a valve job and keep every valve in it's original location, I'm safe?
pretty much , clean them and lap the valves .
