Opening day track woes #2906989
04/05/21 07:54 PM
04/05/21 07:54 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Isn't me or is it normal for the 1st weekend of racing to have horrible traction?
Last weekend was tough.
A lot of spinning and new slicks were burned in.
Seemed a bunch of fast cars were having issues. Thoughts?
Re: Opening day track woes [Re: Sammy] #2906995
04/05/21 08:03 PM
04/05/21 08:03 PM
PA
moparacer Online content
moparacer  Online Content
PA
I haven't been to the track yet for this reason. I am sorting out my suspension and its a waste of time if the track isn't good. Just got the car certed today and if the weather forcast doesn't get better wont be going this coming weekend either.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Opening day track woes [Re: moparacer] #2907009
04/05/21 08:50 PM
04/05/21 08:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
It’s still pretty cold out (below freezing overnight )
....BAD A$$ STREET CAR.....
Re: Opening day track woes [Re: Sammy] #2907044
04/05/21 10:19 PM
04/05/21 10:19 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Always is.....This is why I like having a big tire car. The run isn't aborted for a turn or so of the tire...But yes, new rubber has to get put down before it gets really good...May take a few races...All depends on the track, but at the beginning of the season, its green as can be.
Re: Opening day track woes [Re: Dragula] #2907048
04/05/21 10:31 PM
04/05/21 10:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
131 was outstanding traction wise for the opening day.
Saw more cars on the bumper than you could imagine.
Everybody said the track was awesome( as usual)
It was 65 ish and a bit breezy on Saturday
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Opening day track woes [Re: Dragula] #2907049
04/05/21 10:33 PM
04/05/21 10:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Tracks can be great with no rubber down and freshly scraped. You should watch how big radial races are prepped. Scrape all the time
1.41 best 60 foot
6.56 at 104.17
Re: Opening day track woes [Re: B3422W5] #2907127
04/06/21 06:14 AM
04/06/21 06:14 AM
Dragula Offline
Dragula  Offline
Radials...That seems to be a whole nother animal.....Those I usually see what they call a super prep..Radials pull rubber off the track, slicks put rubber on the track. Two different technologies. Two different types of track prep.
Re: Opening day track woes [Re: Sammy] #2907130
04/06/21 07:07 AM
04/06/21 07:07 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Atleast the first weekend or 2 that a track is open the traction typically isn't the best from my experience. The air temp might be warm, but the ground is still cold/damp/wet whatever from the long winter. I know even late in the season once the nights start to dip into the 30's or even the low 40's traction starts becoming an issue. It may get to 60 during the day, but the ground temp is still cool and it's just hard to have a real sticky track.
