Factory sunroof ´68 Barracuda? #2906887
04/05/21 02:38 PM
04/05/21 02:38 PM
Iceland
BadMoonRacer Offline OP
Iceland
A friend of mine has this ´68 Barracuda Formula S. As can been seen in the photo, the car has a sunroof. Question: Were there factory sunroofs available for ´68 Plymouths? Or could this be dealer installed?
This car is one of the Mopars transported to Europe for final assembly at the Chrysler factory in Rotterdam in Holland; see here: https://www.allpar.com/threads/chry...m-assembly-plant-nekaf-1958-1970.229411/
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Factory sunroof ´68 Barracuda? [Re: BadMoonRacer] #2906891
04/05/21 02:48 PM
04/05/21 02:48 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
As far I know, sunroofs were a new add along the 69 production, not even initially. But dunno if on Barracudas or any other A body. Vinyl top was required.
Re: Factory sunroof ´68 Barracuda? [Re: NachoRT74] #2906894
04/05/21 02:56 PM
04/05/21 02:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
It seems also just on Chargers, which was the only model couldn't be convertible, so the sunroof option was just on them to make somekind of "convertible" option
Re: Factory sunroof ´68 Barracuda? [Re: BadMoonRacer] #2906912
04/05/21 03:22 PM
04/05/21 03:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A 1970 Barracuda was also reported on your side of the pond with a sunroof, it was not a factory option on them either.
Possibly done in the country that imported the bodies to finish their way at final assembly.
Re: Factory sunroof ´68 Barracuda? [Re: Alaskan_TA] #2907000
04/05/21 08:29 PM
04/05/21 08:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The short answer is no, that is not a "factory" sunroof... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Factory sunroof ´68 Barracuda? [Re: Alaskan_TA] #2907056
04/05/21 10:44 PM
04/05/21 10:44 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've seen a '70 (I believe) E-body (Barracuda, maybe) with a sunroof that looked factory, but that back in the early 1980s...
Re: Factory sunroof ´68 Barracuda? [Re: Jim_Lusk] #2907070
04/05/21 11:21 PM
04/05/21 11:21 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
SG-30 books showed NO sunroof Cudas or B-Fishes built with factory (ASC) sunroofs in 1970. I know I've never seen one. Only year was 1972 for the Plymouths.
Re: Factory sunroof ´68 Barracuda? [Re: Sunroofcuda] #2907072
04/05/21 11:29 PM
04/05/21 11:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....interesting 71 Barracuda export model
Re: Factory sunroof ´68 Barracuda? [Re: DAYCLONA] #2907074
04/05/21 11:37 PM
04/05/21 11:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70.....don't know much about it...
Re: Factory sunroof ´68 Barracuda? [Re: DAYCLONA] #2907373
04/06/21 04:57 PM
04/06/21 04:57 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Mine does not have the little pop-up front air foil. Interesting is right.
Re: Factory sunroof ´68 Barracuda? [Re: Sunroofcuda] #2909721
04/13/21 10:11 AM
04/13/21 10:11 AM
Rapid City, SD
sdweatherman Offline
Rapid City, SD
There were no regular production factory sunroof cars built by Chrysler prior to the option being offered on 1969 Chargers. The earliest 1969 sunroof Charger in the registry is sunroof car number 7 which was built in the third week of October, 1968. There is one exception to this in my mind - Chrysler had ASC install a sunroof in a 1968 Charger for the purpose of photographing the option and advertising the new feature in the October issue of Car and Driver (Photo attached). Since Chrysler headquarters officially ordered it up, in my mind you could call it a factory sunroof car. This car has yet to surface.
Barry (Alaskan_TA) mentions a possible scenario for the car in this thread. Since the sunroof was a popular item over in Europe, and this car did see its final assembly across the pond - its possible that the sunroof was added before the car rolled out of the assembly area. If you could prove that was the case - it might add a little value, and add a little interest to the story of the car. But in the end, Chrysler headquarters did not originally designate that particular car to come with the sunroof option.
Scott Rudge
Mopar Sunroof Registry.
1971 GY8 SSP 318/Auto
1971 GB7 SSP 318/Auto factory Sunroof
1972 EV2 SSP 400HP Loaded w factory Sunroof
