Re: RB intake ??
[Re: KOS]
#2906949
04/05/21 05:42 PM
04/05/21 05:42 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
i would think the street dominator would be most likely ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: RB intake ??
[Re: KOS]
#2907254
04/06/21 12:19 PM
04/06/21 12:19 PM
Posts: 3,197 Md.
carnut68
Md.
thx guys I believe the specs should be online but I appreciate the offer.....I think an M1 may work also and I found one gonna have to do some comparison. The M/1 is a good bit taller than a Torker II. I can measure I have both. So far I have run 10.82 @ 125 with the Torker II. Gasket matched no spacer.
America First!
Re: RB intake ??
[Re: carnut68]
#2907364
04/06/21 03:59 PM
04/06/21 03:59 PM
KOS
thx guys I believe the specs should be online but I appreciate the offer.....I think an M1 may work also and I found one gonna have to do some comparison. The M/1 is a good bit taller than a Torker II. I can measure I have both. So far I have run 10.82 @ 125 with the Torker II. Gasket matched no spacer. that would be great ! thx a lot ....to you also B1 duster for the offer and Tex I believe your correct the SD is the lowest.i have a raised area in the hood(cowl) .....its a factory 70 roadrunner hood so slightly taller in the centre.
Re: RB intake ??
[Re: KOS]
#2907708
04/07/21 02:18 PM
04/07/21 02:18 PM
Posts: 3,197 Md.
carnut68
Md.
thx guys I believe the specs should be online but I appreciate the offer.....I think an M1 may work also and I found one gonna have to do some comparison. The M/1 is a good bit taller than a Torker II. I can measure I have both. So far I have run 10.82 @ 125 with the Torker II. Gasket matched no spacer. that would be great ! thx a lot ....to you also B1 duster for the offer and Tex I believe your correct the SD is the lowest.i have a raised area in the hood(cowl) .....its a factory 70 roadrunner hood so slightly taller in the centre. the M/1 measured 5 1/2 on the front of the pad and 5 3/4 on the rear. The Torker II was 4 1/4. A TM7 I have was 4 3/8 on the front and 4 5/8 on the rear.
America First!
