Plugging away..... #2906911
04/05/21 03:22 PM
04/05/21 03:22 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
I've done a boat load of researching on the NGK plug to run in my 440, and after seeing a dozen different part numbers thrown out there, my eyes glazed over and I gave up. 1972 440 from an RV. Stealth heads, Edelbrock 800 CFM AVS2, Edelbrock Performer manifold, full FBO ignition, and a Comp Cams XE268H camshaft. Compression is 8.6:1. What NGK plug should I be running? I like the V power series of NGK's....
Re: Plugging away..... [Re: carrman] #2906945
04/05/21 05:32 PM
04/05/21 05:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Without opening a catalog to see if it even exists......
BCPR5ES
