Swapping to manual brakes-83 Ram
#2906384
04/04/21 05:40 PM
04/04/21 05:40 PM
Posts: 3,547 stratford,ontario,canada
JD340
So the power brake booster on my 83 D150 is on its way out. Searching around online today has shown they're getting hard to come by. On Rockauto, Cardone offers a rebuild service on my existing booster. That puts my truck out of service until I get it back. That, and the fact I haven't heard great things about Cardone's products recently has me considering a swap to manual brakes. So, what I'm wondering, is what steps do I need to take to eliminate the booster? Any help is appreciated.
Nothing to see here. Carry on.
Re: Swapping to manual brakes-83 Ram
[Re: stumpy]
#2906921
04/05/21 03:43 PM
04/05/21 03:43 PM
JD340
scratchn: you the MAN! That's exactly the kind of info I needed! I knew it had been done before, and I was sure I'd read about it here, but my searching skills were not good enough to find the posts. stumpy: Yep I checked Ebay as well for one. Only related results I got were master cylinders or just the mc reservoir.
[Re: scratchnfotraction]
#2907292
04/06/21 01:01 PM
04/06/21 01:01 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
ez pz.. you need a manual brake rod that fits you pedal hook up. this was my hang up on my 85/88 trucks.
older manual brakes use the shoulder bolt and rod with the pedal drilled for bolt. so get the pedal/rod/bolt from a manual brake parts truck.
not sure if the mid 80s trucks use a stud/clip/pedal or used a shoulder bolt//rod/pedal but if you find a parts truck.
there is also a firewall reinforcement plate between the MC and firewall. it is size and shape of the foam gasket behind the booster/firewall, you can use it as a template to make you one 1/8" thick metal. Quick question for you. I have been planning to do the manual brake setup on my 88 Ramcharger. I pulled a manual brake rod, and a brake pedal from a donor 74ish D100. Do you think that brake pedal will bolt in to the 88? Then my rod to pedal issue isn't an issue. I have been hunting for a manual brake 88 but haven't found one in years of searching. I am not even sure if it was an option at that point.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
