8.75 Sure grip bearing I.D.
#2906313
04/04/21 02:41 PM
04/04/21 02:41 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I picked up a sure grip for an 8.75 this winter, and the carrier bearings were pretty beat up. Did a poor job of measuring for new ones and ordered a set of bearings with a 2" I.D. They are too loose. Measured with an actual caliper, and the sure grip shaft is 1.96", which is a bit too big to try to press a 1.80" bearing onto. Does anyone have a part number for a Timken bearing with a 1.96" I.D. and an O.D. for a 489 case? Thanks.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 8.75 Sure grip bearing I.D.
[Re: Alaskan_TA]
#2906327
04/04/21 02:58 PM
04/04/21 02:58 PM
OhioMopar
Mt.Gilead, Ohio
He's the one I ordered the bearings from. Lol. I'm going to call him tomorrow if I don't find anyone else that knows the answer. Thanks.
[Re: fourgearsavoy]
#2906328
04/04/21 03:00 PM
04/04/21 03:00 PM
OhioMopar
Mt.Gilead, Ohio
What sure-grip are you using ? Clutch or cone type will make a difference, 1.8 for the early or clutch type or 2.0 for the later cone type . I have both types here so when I get a minute today I will get you the numbers but they might be Koyo bearings. Not to sure about the 1.96 bearing though Gus It's a clutch type. I bought 2.0, my buddy had some 1.8 in stock and he checked them when he pressed the old bearings off. Neither will work. I think if there is an oddball bearing/sure grip unit that was made for one year and has discontinued bearings, I will be the one that bought it.
[Re: OhioMopar]
#2906332
04/04/21 03:09 PM
04/04/21 03:09 PM
OhioMopar
Mt.Gilead, Ohio
Is there any chance the surface is sure grip is tapered after the bearing surfaces?
[Re: OhioMopar]
#2906410
04/04/21 06:23 PM
04/04/21 06:23 PM
Posts: 5,924 ohio
ruderunner
ohio
Got numbers on the old bearings?
Angry white pureblood male
[Re: ruderunner]
#2906633
04/05/21 04:19 AM
04/05/21 04:19 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I fit a clutch kind (yukon) SG carrier on my 489 case and used stock bearings. Fit just like the open carrier. Never had to take care about any measurement. This guide has been reposted on several websites along the years, being copied and pasted from web to web. http://www.crazysmopar.com/tech_rearax.htmlPNs are there.
[Re: jlatessa]
#2906819
04/05/21 10:49 AM
04/05/21 10:49 AM
OhioMopar
Mt.Gilead, Ohio
After talking with Cass, we're thinking it may be a unit out of a 9.25, not an 8.75 as it was advertised at the swap meet. More to come.
[Re: NachoRT74]
#2906871
04/05/21 01:31 PM
04/05/21 01:31 PM
Posts: 25,941 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yeah, reposted with lots of the same incorrect info. Notice they list the '62-'70 B-body housings as being the same width. The archives here are a better source.
[Re: John_Kunkel]
#2907197
04/06/21 10:23 AM
04/06/21 10:23 AM
NachoRT74
Valencia, España
well, so far so good it has worked for me on PNs and references
