A Low-Buck Headlight Relay Conversion #2905334
04/02/21 11:56 AM
04/02/21 11:56 AM
Nashville, TN
Rustymuscle Offline OP
Mopar Connection Magazine
Nashville, TN
Nighttime driving may not be something we often do with our classic Mopars, but wouldn’t it be enjoyable to have the best lighting available when low-light driving is necessary? Over the years, many vehicles have been updated with halogen headlamps. Of these cars, most have not had the wiring improved. The factory wired the headlamp switch in series with the parallel-wired headlamps. The series section of the circuit required the headlamp switch to flow the total circuit amperage. Any resistance in the circuit caused a decrease in voltage available to each headlamp.
Read the whole story at Mopar Connection Magazine HERE:
Mopar Connection Magazine, your source for daily news, real-world tech, features and much more.
Got a comment, question, or a story? Email me at kevin.shaw@shawgroupmedia.com
Re: A Low-Buck Headlight Relay Conversion [Re: Rustymuscle] #2905449
04/02/21 04:19 PM
04/02/21 04:19 PM
CA
crackedback Offline
crackedback  Offline
CA
You shouldn't pull power for any accessories on an OEM wired muscle era mopar from the starter relay. It's an additional stress on the bulkhead connector.
I sell everything in a one stop shop end to end for about the same as the items in your article, 85ish plus shipping. Mine also includes shrink tube to cover all the wiring.
It's a great upgrade without a doubt.
Re: A Low-Buck Headlight Relay Conversion [Re: crackedback] #2905905
04/03/21 05:44 PM
04/03/21 05:44 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Draw directly from battery?
China is the enemy.
Re: A Low-Buck Headlight Relay Conversion [Re: 1972CudaV21] #2905989
04/04/21 12:26 AM
04/04/21 12:26 AM
CA
crackedback Offline
crackedback  Offline
CA
same as starter relay, bad spot
Moderated by  Rustymuscle
