Re: CAL TRACS WITH STOCK SPRINGS?
[Re: one bad fish]
#2905041
04/01/21 06:46 PM
04/01/21 06:46 PM
Posts: 4,700 Wichita
GY3
Wichita
The Cal-tracs are a system and work best when you use all their components.
I tried them with SS springs and the car porpoised badly.
I ended up using the split mono's with the Cal-tracs and the Rancho/Calvert 9 position shocks.
With this setup it runs mid 1.50 60 ft.'s n/a and best of 1.36 with a 250 nitrous shot. All this is in a 3,700 lbs. car using only 275 ET Street Pro's.
I did recently upgrade to a Double Adustable Viking Crusader rear shock. I really need fronts for better control (currently 3 position adjustable CE shocks) and will upgrade them this Fall but so far the rears are working really well with the n/a tune. I would recommend a good double adjustable shock on all 4 corners at your power level.
[Re: viperblue72]
#2905052
04/01/21 07:13 PM
04/01/21 07:13 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
I also tried them with 002-003 springs. 635 hp,5900 flash, 4.56, 3100 lbs.I needed a really tight 50/50 valving or else the rear end would pound the floor pan. Travis told me to run a stock type spring, so you should be good, but the stick and the weight will require a good shock. You might consider mapping out the anti-squat (neutral) line, and playing with ride heights. At least that’s my opinion.
[Re: Leigh]
#2905060
04/01/21 07:48 PM
04/01/21 07:48 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
Radials & a stick shift is a no no
[Re: viperblue72]
#2905105
04/01/21 09:27 PM
04/01/21 09:27 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
i run Caltracs with Mopar XHD springs , have done for over 10 years and various power upgrades . From footbrake to transbrake leaving @4500 and currently back to foot brake . I would like to try split monos , weight reduction and probably stiffer . BUT i am concerned how they will hold up to daily driver , probably ok , and when i go racing i have rear race wheels , 29.5x10.5R15 PBR , trolley jack , 20L fuel , spare tyre and assorted tools etc in the boot , not sure .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: viperblue72]
#2905162
04/01/21 11:54 PM
04/01/21 11:54 PM
Posts: 31,073 Oregon
AndyF
How well would these work with stock springs on my ‘74 Cuda? I am currently going to run drag radials 295/65/15 and it’s a 4-speed car. I also don’t know what shocks to run. Front or rear. It’s going to be mostly street and some strip. The engine is a 511 that made 743hp/700tq. Rear is a Dana 4.10. I know the 4-speed is the weak link but I’ll see how it will hold up with no power shifting and going as easy as I can. The budget is getting tighter which is why I am asking how well this will work for now. It will work fine as long as you don't use more than half throttle.
[Re: CSK]
#2905398
04/02/21 02:10 PM
04/02/21 02:10 PM
Posts: 2,141 junction city oregon
viperblue72
Radials & a stick shift is a no no I know it isn’t ideal. Radials didn’t even work well with my last small block. The radials are mostly for the street. I plan to run a 29.5 bias when funds allow. I’ll go ahead and order the mono-leafs. I just figured some have tried them with stock leafs and could tell me how it would or wouldn’t work. AndyF lol.
[Re: viperblue72]
#2905402
04/02/21 02:15 PM
04/02/21 02:15 PM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
You will find folks that have got them to work with most any spring.
However IMO most folks the best results the quickest with the Calvert spring they recommend for your car.
[Re: tex013]
#2905412
04/02/21 02:59 PM
04/02/21 02:59 PM
CSK
Pattison Texas
Tex I have over 11k miles on my split monos, & they were used when I got them, my Charger aint no light weight ether
[Re: viperblue72]
#2905426
04/02/21 03:27 PM
04/02/21 03:27 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
Cal Tracs were develop for NHRA stock class racing back when you had to have stock springs in your race car, I use to race against John Calvert in stock in division 7, he has ran a 1968 428 Cobra Jet motor in his 4 speed fast back Mustang long before racing in NHRA. He has raced the same car in NHRA SS also with his bars and stock springs long ago also so stock spring can be made to work fine Are there better springs available today, you betcha As far as stick shifts and radials I don't think I would do that now Buy another set of rims and bias 4 speed drag tires and go win some races
[Re: Cab_Burge]
#2905477
04/02/21 05:08 PM
04/02/21 05:08 PM
viperblue72
Cal Tracs were develop for NHRA stock class racing back when you had to have stock springs in your race car, I use to race against John Calvert in stock in division 7, he has ran a 1968 428 Cobra Jet motor in his 4 speed fast back Mustang long before racing in NHRA. He has raced the same car in NHRA SS also with his bars and stock springs long ago also so stock spring can be made to work fine Are there better springs available today, you betcha As far as stick shifts and radials I don't think I would do that now Buy another set of rims and bias 4 speed drag tires and go win some races Cab, I’m hoping to find some wheels/tires at the swap meets. I’m trying to get my car ready for the function for junction cruise. I’ll be at Woodburn tomorrow spectating. 👍
[Re: CSK]
#2905634
04/03/21 01:12 AM
04/03/21 01:12 AM
tex013
Sydney,Australia
Tex I have over 11k miles on my split monos, & they were used when I got them, my Charger aint no light weight ether Thanks . I do 5/8000miles a year . I guess i should give them a call . Tex
[Re: tex013]
#2905642
04/03/21 05:26 AM
04/03/21 05:26 AM
Posts: 2,933 A shed in England
Tig
A shed in England
Tex I got my -1" ride height Caltrac Split Mono's in 2000, I got bored waiting for them to "settle" so in 2016 I welded on some 1" lowering pads . I don't think you will have a problem
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
