Page 2 of 5 1 2 3 4 5
Re: 426 wedge [Re: mr_340] #2904453
03/31/21 03:21 AM
03/31/21 03:21 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
The engine would have no hp with a 8:1 compression if l did that.l could bore it to a 440 and use standard 440 pistons which be The same price as those low compression 383 pistons are. Mise well bore to a 440 then get another crank it be about the same price.
Re: 426 wedge [Re: mopar muscle7271] #2904523
03/31/21 10:03 AM
03/31/21 10:03 AM
AndyF Offline
AndyF  Offline
I used Diamond pistons in my 426W. Made a little over 600 hp on the dyno with a mild hyd roller cam and Trick Flow 240 heads.
Re: 426 wedge [Re: AndyF] #2904530
03/31/21 10:22 AM
03/31/21 10:22 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Very interesting aF ...
More info please !
Re: 426 wedge [Re: AndyF] #2904545
03/31/21 10:49 AM
03/31/21 10:49 AM
las vegas,nv
las vegas,nv
That's sick what was the cost of them? Do you still have your 426 wedge specs when you had them made custom?
Re: 426 wedge [Re: mopar muscle7271] #2904601
03/31/21 01:04 PM
03/31/21 01:04 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Probably less $$ than 383 pistons and a stroker crank and then you also get lighter pistons with decent compression, better rings and valve notches.
Re: 426 wedge [Re: GomangoCuda] #2904609
03/31/21 01:20 PM
03/31/21 01:20 PM
las vegas,nv
las vegas,nv
Either put 426 wedge pistons in or bore it 070 for standard 440 pistons.l rather just try and get 426 wedge pistons first.
Re: 426 wedge [Re: mopar muscle7271] #2904632
03/31/21 02:23 PM
03/31/21 02:23 PM
I've had to bore several 426 blocks, both street and M.W. blocks to 4.320 and used 440 pistons in them due to to much taper in the 4.310 bores, no problems on any of them shruggy
I did have them all sonic tested first though boring them larger up
As far as strokers and lighters pistons compare to the stock stroke RB pistons weight the longer the stroke and the longer the rod the lighter the pistons get up
Can you say 526 grams with the pins boogie up
Re: 426 wedge [Re: mopar muscle7271] #2904658
03/31/21 03:57 PM
03/31/21 03:57 PM
AndyF Offline
AndyF  Offline
I don't recall, I'd have to look it up. The billet valve covers probably cost more than the pistons. It wasn't a cheap build.
Re: 426 wedge [Re: AndyF] #2904659
03/31/21 04:02 PM
03/31/21 04:02 PM
las vegas,nv
las vegas,nv
Oh ok lmk if you find your specs at least,badass 426 wedge you built
Re: 426 wedge [Re: Cab_Burge] #2904660
03/31/21 04:03 PM
03/31/21 04:03 PM
las vegas,nv
las vegas,nv
Good to know thanks for more info on boring to a 440 if l do that.
Re: 426 wedge [Re: mopar muscle7271] #2904723
03/31/21 08:41 PM
03/31/21 08:41 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
A friend of mine has some .075 over flat top ones. $250
Re: 426 wedge [Re: old_racer] #2904742
03/31/21 09:08 PM
03/31/21 09:08 PM
las vegas,nv
las vegas,nv
There a 426 wedge with a 075 bore or a 440 piston? Pm sent
Re: 426 wedge [Re: mopar muscle7271] #2904803
04/01/21 02:26 AM
04/01/21 02:26 AM
las vegas,nv
las vegas,nv
Still lookin for all options and sizes available others may have before l make choice on what to do.
Re: 426 wedge [Re: Cab_Burge] #2904831
04/01/21 07:28 AM
04/01/21 07:28 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Do tell, CH? That must have been a light as hell pin
Re: 426 wedge [Re: Alchemi] #2905193
04/02/21 06:55 AM
04/02/21 06:55 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Hi All,
A true 426ci engine is a 4.252 bore.
If you go 0.062 over, it will be a 438ci engine...
Doesn't quite have the same ring to it?
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 426 wedge [Re: Gtxxjon] #2905345
04/02/21 12:14 PM
04/02/21 12:14 PM
las vegas,nv
las vegas,nv
A 426 wedge is a little different then 426 hemi
Re: 426 wedge [Re: mopar muscle7271] #2905420
04/02/21 03:16 PM
04/02/21 03:16 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
DWTFYW.
Floyd Lippencott IV
Re: 426 wedge [Re: mr_340] #2905638
04/03/21 03:09 AM
04/03/21 03:09 AM
las vegas,nv
las vegas,nv
I rather you use the 426 stock crank then get another one.ld rather not use 383 pistons either
Re: 426 wedge [Re: mopar muscle7271] #2905776
04/03/21 12:38 PM
04/03/21 12:38 PM
I faintly remember someone, years ago, who tried using oversize 383 pistons in a 426 wedge and they were either way to low or high in relation to the deck to be used shruggy The compression heights, deck heights, stroke and rod lengths are different on them scope
Re: 426 wedge [Re: Cab_Burge] #2905850
04/03/21 02:52 PM
04/03/21 02:52 PM
las vegas,nv
las vegas,nv
What I though 383 pistons won't work that well.
