Re: 413 industrial block [Re: JAKE68] #2484066
04/17/18 09:25 AM
04/17/18 09:25 AM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Thank you for clearing that up. Guess our's is a 426. Do you know if the block is thicker on the 426 than the 413? Pretty sure our engine builder told us it's .060 over. Can't find our receipt with the specs after Dad moved.
Re: 413 industrial block [Re: Tommy D] #2484232
04/17/18 02:44 PM
04/17/18 02:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The block I got was a 426--4-1/4 bore, I had it bored 60 over, rite out of the crane. I traded a 3-3/4 crank for it, seems he had picked up an early industrial 413 with the extended crank and needed the later style crank to mate back up to ?? Never asked if the engine ran the truck or the crane.
Re: 413 industrial block [Re: Porter67] #2484406
04/17/18 10:39 PM
04/17/18 10:39 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Being in the business for almost 40 years, big block cores (cases) are getting hard to find, at least out here, SoCal.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 413 industrial block [Re: an8sec70cuda] #2484528
04/18/18 10:45 AM
04/18/18 10:45 AM
warren, mich.
dwayne welder Offline
warren, mich.
I would love to flow those heads.
Re: 413 industrial block [Re: SCATPACK 1] #2485011
04/19/18 11:18 AM
04/19/18 11:18 AM
an8sec70cuda Offline OP
Originally Posted By SCATPACK 1
IF you don't care, post up some pictures of the spark plugs and combustion chamber. I am intrigued by that design. Never ever saw it before. And I thought I had worked on every Mopar block ever made.
Here's a couple of pics for you. First to show you how the spark plugs are positioned and the 2nd to show how much taller these heads are than standard BB heads. The intake manifold is supposed to work on normal heads, but I have not verified this.
I'm planning on stripping it to the shortblock this weekend, get some more pics, and post for yall on Monday.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 413 industrial block [Re: an8sec70cuda] #2485204
04/19/18 06:11 PM
04/19/18 06:11 PM
dogdays Offline
dogdays  Offline
IF you check the casting number lists, there is ONE casting number that was used for 413 AND 426 industrial engines. There are, I believe, other industrial 413 casting numbers and industrial 426 casting numbers. AS WITH ANY MOPAR CASTING, let the sonic checker tell you the answer. That "underbored 440" crap is just that, crap.
The problem with 413s is that they should be free engines, the same as 318s and 361s. But give a novice a "bigblock Mopar" engine and he'll think it's gold. Those motorhome 413s show up on Craigslist for $800, makes me puke. Now if they were priced right, they might be interesting. But a 360 with a 4" crank and decent heads will outrun one in the same car.
R.
Re: 413 industrial block [Re: dogdays] #2486769
04/23/18 12:26 PM
04/23/18 12:26 PM
A few more pics...got the heads off. Trying to get it unstuck.
Valve sizes are real small...1.88 intake, 1.50 exhaust.
The intake manifold from this 413 motor WILL work on any other RB w/ the typical cylinder heads. I bolted it on a 440 I have on another stand and it fit right up.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2486770
04/23/18 12:27 PM
04/23/18 12:27 PM
Dished pistons and extra ribs on the side of the block.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2904280
03/30/21 01:25 PM
03/30/21 01:25 PM
Digging this old thread back up for a quick update. I bought a sonic checker and checked the walls on this 413 block.
Like Cab, dogdays, and others have said...you can't bore this thing to 440 bore size. There's enough meat to go .060" or .070" oversize, but no more than that.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2904340
03/30/21 05:10 PM
03/30/21 05:10 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Diamond makes a 4.25 bore BB shelf piston, they'll probably be able to move the CH for you so it'll work. S/F....Ken M
Re: 413 industrial block [Re: EchoSixMike] #2904471
03/31/21 06:51 AM
03/31/21 06:51 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Good timing, Top fuel Mike is getting some 413 pistons made ( hopefully) with some decent compression.
But it’s still a truck motor and just like the 383 a small bore cousin of a better option (400)... stirthepot
Oh yeah, mine 413 is going in a 64 D200, which is a ‘truck’ cos I can’t find a 426 boohoo... violin
I was gonna use the ‘truck’ heads but they is so flipping heavy it’s scary... XmasTruck
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 413 industrial block [Re: an8sec70cuda] #2904484
03/31/21 08:59 AM
03/31/21 08:59 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have a couple of those engines laying around in the barn from motor homes. Complete from carb to pan including accessories. One still has the tranny attached. Just use them for nuts and bolts for other projects.
Master, again and still
Re: 413 industrial block [Re: DaveRS23] #2904485
03/31/21 09:06 AM
03/31/21 09:06 AM
I figure I'll hold onto it mainly b/c it has a good forged crank and a set of LY rods. It's wrapped up and sitting in a corner under some shelves next to a bunch of 440s. I got rid of all my low deck stuff, so this one fits right in, lol.
It is nice to have some extra complete core motors for random parts every now and then.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2904487
03/31/21 09:11 AM
03/31/21 09:11 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
If I remember correctly the crank is the older design from the fifties?
About 1/2” longer and Eight bolts?
Great for a custom build but no good for a stock trans.
Re: 413 industrial block [Re: Gtxxjon] #2904489
03/31/21 09:13 AM
03/31/21 09:13 AM
I'm sure some have that type of crank, but this one doesn't. It's a standard 6 bolt crank w/ the typical flange.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2904509
03/31/21 09:51 AM
03/31/21 09:51 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Nice one 8secs!
I had an 8secs Street Dart back in the 90's too. (in Avatar)
Koffel 547ci engine with a bruno lenco ran 8.30 @ 180 best ever!
I still dream of those 'Days of Glory past' lol...
Re: 413 industrial block [Re: an8sec70cuda] #2908459
04/09/21 04:47 PM
04/09/21 04:47 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If you are not going to use those heads, I could use the set of push rods and head bolts for a frankenstein 440 with 413 heads I am building. They are too long to work with regular heads.
Re: 413 industrial block [Re: mgoblue9798] #2913780
04/23/21 09:05 AM
04/23/21 09:05 AM
I would have gladly given them to you, but they went to the scrap yard 2 years ago shortly after I started this thread.
CHIP
