I used to hit the U Pull It and pulled 2 at diff times off early A Bodies with the small head bolt like that.
But we're cast iron adapters not aluminium. The stock 1972 340 Challenger I was 3rd owner of and knew the other 2 owners had one on it it was aluminium with large head bolt.
All the 70 up ones I pulled were large bolt head even the FMJ ones were large bolt.
Note the F, M And J Body ones are different looking bodies but same large.head bolts.
Steel Wheels, disk brakes and 90 degree oil adapters and 8 3/4 sure grips were my go to easy grabs at the U Pull It so saw a good bit of them.
