Page 1 of 5 1 2 3 4 5
426 wedge #2903343
03/27/21 11:44 AM
03/27/21 11:44 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Anyone have reasonable price 426 wedge pistons 030? Where to get some at that won't break the bank?lol
Re: 426 wedge [Re: mopar muscle7271] #2903362
03/27/21 12:59 PM
03/27/21 12:59 PM
Max wedge or street wedge? What compression ratio are you wanting?
Either one will not be easy and cheap shruggy
Re: 426 wedge [Re: Cab_Burge] #2903367
03/27/21 01:11 PM
03/27/21 01:11 PM
las vegas,nv
las vegas,nv
It's a street wedge block Hughes and Campbell want to much for pistons.probably 10:1 compression don't want to run race fuel.
Re: 426 wedge [Re: mopar muscle7271] #2903372
03/27/21 01:48 PM
03/27/21 01:48 PM
E
earlymopar Offline
earlymopar  Offline
E
Check with these guys:
http://www.ebaystores.com/Johnsons-Speed-Warehouse
I think they buy and have bought up a lot of old warehouse stock from the 60's and possibly other eras. I often find that they have what I need. I bought a set of NOS TRW forged pistons for my poly 318 and found that they had several different sets in various over-bores. There are also a few M/W sites that may be helpful if you haven't already checked.
Do you have the heads you want to run?
Re: 426 wedge [Re: earlymopar] #2903400
03/27/21 03:32 PM
03/27/21 03:32 PM
las vegas,nv
las vegas,nv
They only have one 426 wedge piston l seen.
Re: 426 wedge [Re: mopar muscle7271] #2903503
03/28/21 01:44 AM
03/28/21 01:44 AM
I would have your block sonic tested to see how thick both the thrust surfaces are, if they are all .180 or thicker and at least .120 thick after boring on the front and back sides of all cylinder walls you could think about boring it to 4.320, which is the standard 440 bore size work scope twocents
What year was your block cast in? Is it a street wedge casting or or is it a 1964 M.W. casting used in a 1964 or early 1965 street car build with the smaller heads and oil pan pickup? scope
As far as compression ratio and iron heads I would not put more than 9.5 to 1 compression ratio in it max twocents Pump gas is not going to get better, is it work
Re: 426 wedge [Re: Cab_Burge] #2903504
03/28/21 03:10 AM
03/28/21 03:10 AM
las vegas,nv
las vegas,nv
It's a 64 426 street wedge block,not tryin to run race fuel in it.
Re: 426 wedge [Re: mopar muscle7271] #2903637
03/28/21 02:01 PM
03/28/21 02:01 PM
There are a lot more choices on 440 standard pistons than 426 street wedges, correct? shruggy
I would order a set of standard 440 350 HP 1968 to 1971 pistons scope
Re: 426 wedge [Re: mopar muscle7271] #2903663
03/28/21 03:18 PM
03/28/21 03:18 PM
AndyF Online content
AndyF  Online Content
If you want to build a 426W then you have to buy semi-custom pistons.
Re: 426 wedge [Re: AndyF] #2903838
03/29/21 12:14 AM
03/29/21 12:14 AM
las vegas,nv
las vegas,nv
Yah l see that wondering if anyone would chime in on here first seein if they would any.seen ads on the past sayin someone has pistons they have and sell.
Re: 426 wedge [Re: mopar muscle7271] #2904260
03/30/21 11:42 AM
03/30/21 11:42 AM
las vegas,nv
las vegas,nv
No one at all has any layin around?
Re: 426 wedge [Re: mopar muscle7271] #2904315
03/30/21 03:30 PM
03/30/21 03:30 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Try Egge? By the way, need a manifold?
Abe Lincoln
Re: 426 wedge [Re: dart4forte] #2904325
03/30/21 03:56 PM
03/30/21 03:56 PM
las vegas,nv
las vegas,nv
Tried egge,they have to custom make he said
Re: 426 wedge [Re: mopar muscle7271] #2904336
03/30/21 04:39 PM
03/30/21 04:39 PM
A727Tflite Offline
A727Tflite  Offline
I have a fresh street wedge block with pistons matched. The pistons were originally high ratio Maxwedge but had the domes cut to low ratio height with the plans to run as a stocker back in the early 90’s. Been bagged ever since.
.030”, bored and honed with plates, parallel decked for clean up only, fresh cam bearings, was baked and blasted.
Has the A stamp on the pad - 1965.
Won’t separate the pistons.
Re: 426 wedge [Re: A727Tflite] #2904353
03/30/21 05:59 PM
03/30/21 05:59 PM
las vegas,nv
las vegas,nv
You should sell it l know someone would want it and build it.
Re: 426 wedge [Re: mopar muscle7271] #2904358
03/30/21 06:34 PM
03/30/21 06:34 PM
A727Tflite Offline
A727Tflite  Offline
You should sell it l know someone want it and build it.
PM sent
Re: 426 wedge [Re: A727Tflite] #2904375
03/30/21 07:30 PM
03/30/21 07:30 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Try Diamond?
Abe Lincoln
Re: 426 wedge [Re: mopar muscle7271] #2904376
03/30/21 07:32 PM
03/30/21 07:32 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Put an ad on the HAMB. Also try classracer.com
Abe Lincoln
Re: 426 wedge [Re: dart4forte] #2904389
03/30/21 08:39 PM
03/30/21 08:39 PM
las vegas,nv
las vegas,nv
Oh ok I'll try them
Re: 426 wedge [Re: mopar muscle7271] #2904442
03/31/21 01:18 AM
03/31/21 01:18 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
BMJW
Floyd Lippencott IV
