2020 T/A 392
#2904063
03/29/21 06:16 PM
03/29/21 06:16 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Hello guys, what heads are on a 2020 Scat Pack 392, how do they flow & does the stock Intake manifold keep up with them, also what are the cam specs, I am new to the Gen 3 stuff, I looked on the search function & still confused which is not hard to do with me LOL , Thank you, Charlie
Re: 2020 T/A 392
[Re: CSK]
#2904102
03/29/21 09:06 PM
03/29/21 09:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Seems most guys are claiming around 330 340 CFM on stock heads, some claiming as high as 400 ported. Also seems that a 392 SRT8 can make around 580 HP without pulling the valve covers with the addition quality long tube headers and a tall M1 style intake and big throttle body or carb, thats why hotrod magazine didn't bring one when they did a chevy and ford motor up the same way, they even got cam upgrades and still would have lost to the 6.4. Dynos and drag strip numbers both seem to be backing this up. I am sure the stock intake is some of the hold up but not all of it, on the other hand you port the heads, big cam, more compression the stock intake will be an even bigger hold up.
Re: 2020 T/A 392
[Re: CSK]
#2904270
03/30/21 12:31 PM
03/30/21 12:31 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
The intake has a flap that switches it from long runner to short when the RPM's get up, it works beautifully and is really cool to see on a dyno sheet. Engine Masters show has an episode on it, heads are called "Apache", you'll find a lot if you google that. https://www.hotrod.com/articles/ccrp-1210-inside-the-g3-hemi-cylinder-head/
