Re: Line Lock
[Re: Mr.Yuck]
#2903578
03/28/21 11:59 AM
03/28/21 11:59 AM
Posts: 16,495 On the run…
BloFish
On the run…
The unit itself, or the control button?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: Line Lock
[Re: BloFish]
#2903706
03/28/21 05:46 PM
03/28/21 05:46 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The unit itself, or the control button? Unit.
Re: Line Lock
[Re: Mr.Yuck]
#2903744
03/28/21 07:24 PM
03/28/21 07:24 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
below master cylinder on inner fender . But mine is mounted in rear brake circuit in reverse direction.
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Line Lock
[Re: cruzin]
#2904349
03/30/21 05:53 PM
03/30/21 05:53 PM
BloFish
On the run…
That’s where mine is mounted.
Re: Line Lock
[Re: cruzin]
#2904526
03/31/21 10:11 AM
03/31/21 10:11 AM
Mr.Yuck
Brookeville, Md
Underneath the master cylinder. This is on an E-body. I like that.. Maybe I'll make a bracket and do that.
Re: Line Lock
[Re: dvw]
#2904608
03/31/21 01:18 PM
03/31/21 01:18 PM
Posts: 19,488 north of coder
moparx
I keep a rebuild kit with me. If it's real racecar you need quick access. Doug how often does a line lock need freshened up ? what is included in the kit, and how old of a line lock can be rebuilt ? as always, TIA.
