Torsion bar bolts uneven 68 b body
#2903378
03/27/21 02:06 PM
03/27/21 02:06 PM
Posts: 949 Indiana
68_661charger
Indiana
I rebuilt the front end on my 68 maybe 10years ago and set the front level side to side but the drivers torsion bar bolt is turned in farther than the passenger side. Car is still level after all these years. Is this normal for the bolts to be in different lengths?
Re: Torsion bar bolts uneven 68 b body
[Re: fastmark]
#2903507
03/28/21 06:48 AM
03/28/21 06:48 AM
Posts: 5,967 ohio
ruderunner
ohio
He put it together 10 years ago. If there was a problem then, it would have made itself apparent by now. That's not to say that a 50 year old bar won't fail.
If ride height is still ok, I certainly wouldn't worry.
Angry white pureblood male
[Re: NITROUSN]
#2903519
03/28/21 08:28 AM
03/28/21 08:28 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
and same as a coil from one side could get an earlier worn process than the other side, the T bars are the same. There is not a PERFECT matching process on every piece built/casted. One T bar could get cooler faster than the other when being templated, or some contamination particle or air buble trapped into the metal... whatever thing could happen
fortunatelly T bars are adjustable to easilly get the suspension leveled
[Re: NachoRT74]
#2903594
03/28/21 12:49 PM
03/28/21 12:49 PM
Posts: 5,967 ohio
ruderunner
ohio
For reference, I was under my roadrunner today getting things ready for summer. My t bar adjuers are about 3/8th inch difference. Seems like you're in the ballpark.
[Re: NachoRT74]
#2909345
04/12/21 03:30 AM
04/12/21 03:30 AM
NachoRT74
Valencia, España
BTW, driver side of the car is heavier than passenger side. Steering box and parts, master cylinder and brake booster. Dunno how much woild affect that on the T bars adjusting.
Althought engine is offset to the passenger side by an inch or so.
[Re: NachoRT74]
#2909383
04/12/21 09:15 AM
04/12/21 09:15 AM
Posts: 1,387 Az
69hemibeep
Az
Check and see if the long one is seated in the socket above. Common mistake.
1969 Hemi Roadrunner 2nd owner
[Re: NITROUSN]
#2909404
04/12/21 10:21 AM
04/12/21 10:21 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
That's why they are called adjustment bolts. If you had a coil design you would have to live with the non adjustable differences. grinder = adjustable..lol
