OK How to ID a 71 Power Brake booster? #2903062
03/26/21 04:13 PM
03/26/21 04:13 PM
SC
V194 Offline OP
V194  Offline OP
SC
Trying to get a grasp on what a 1971 Power Brake booster looks like.
Application: 1971 Plymouth 'Cuda 440+6 4 Speed Front disc brakes
1. It should be cadmium plated correct? With a bare master cylinder?
2. Where or is there a date code on it?
3. Where is the PN on it?
Photos of a correct unit?
Re: OK How to ID a 71 Power Brake booster? [Re: V194] #2903069
03/26/21 04:24 PM
03/26/21 04:24 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I researched this subject for my V code ‘71 Challenger, and what I have found is that there could either be a black painted Bendix booster, same part as used in ‘70, or a cad plated style made by Midland Ross. I’m not sure if both were used all year, or if the Bendix was used earlier in the production run and then was transitioned to the Midland Ross later in the cycle.
The master cylinders used starting in 71 were finished in a gray parkerized coating that resembled bare steel, though that’s based on NOS ones I’ve seen, I don’t know if 1971 production era master cylinders were still painted black like disc brake Mopar MCs were in ‘67 through ‘70.
Re: OK How to ID a 71 Power Brake booster? [Re: Mastershake340] #2903073
03/26/21 04:42 PM
03/26/21 04:42 PM
SC
V194 Offline OP
V194  Offline OP
SC
Remember this is for a 71 R/T Power disc brakes car.
Re: OK How to ID a 71 Power Brake booster? [Re: V194] #2903082
03/26/21 05:09 PM
03/26/21 05:09 PM
Crook County, ILL
Crook County, ILL
That's what I have too! My car was built in October '70, the Bendix booster and MC were on it when I bought it, so I can't say if that is how it was when it rolled off the assembly line.
Re: OK How to ID a 71 Power Brake booster? [Re: Mastershake340] #2903097
03/26/21 06:00 PM
03/26/21 06:00 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
99 % sure from what i have seen that this is nos 71. early production may be black... i have some under hood pictures of mine when new . going to try and find the pics to verify as a fact.
Re: OK How to ID a 71 Power Brake booster? [Re: ek3] #2903100
03/26/21 06:04 PM
03/26/21 06:04 PM
Crook County, ILL
Crook County, ILL
That’s an NOS Midland Ross booster.
Re: OK How to ID a 71 Power Brake booster? [Re: Mastershake340] #2903196
03/26/21 09:45 PM
03/26/21 09:45 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have several NOS 71 midland Ross and the part no and date are on the aluminum tag held by the bolt that holds the band that holds the two halves together.
Re: OK How to ID a 71 Power Brake booster? [Re: fastmark] #2903201
03/26/21 09:59 PM
03/26/21 09:59 PM
VA
dragon slayer Offline
VA
But the corrosion coating specified for a part to be sold out of stock by a dealer can be different then what was specified for assembly line. Example the MC Lid of the Bendix sold as NOS. They were plated and not black. My understanding that this became the standard for what a car should have being restored. Yet that is not how it came off the assembly line. They were painted black. Yet you still see highly restored examples of cars with plated lids on bendix power disc cars of the 67 to 71 vintage. Plus the vendors changed. Hence all those different examples especially for the 71 up B/E bodies.
Re: OK How to ID a 71 Power Brake booster? [Re: ek3] #2903206
03/26/21 10:10 PM
03/26/21 10:10 PM
Highland, MI.
Sunroofcuda Online content
Sunroofcuda  Online Content
Highland, MI.
Very cool. So if someone needed one, are they available through parts sources either reproduction or rebuilt or even new?
Re: OK How to ID a 71 Power Brake booster? [Re: Sunroofcuda] #2903216
03/26/21 10:28 PM
03/26/21 10:28 PM
E
ek3 Offline
ek3  Offline
E
Re: OK How to ID a 71 Power Brake booster? [Re: V194] #2903236
03/26/21 11:29 PM
03/26/21 11:29 PM
SC
V194 Offline OP
V194  Offline OP
SC
Any thoughts on the notion that early 71 cars had painted boosters and later cars had cadmium plated.
Re: OK How to ID a 71 Power Brake booster? [Re: Mastershake340] #2903240
03/26/21 11:42 PM
03/26/21 11:42 PM
E
ek3 Offline
ek3  Offline
E
now i am really wondering ... if this car is oe gold , look at the booster on it ! --->>> https://www.mecum.com/lots/FL0115-204293/1971-dodge-hemi-challenger-rt/
Re: OK How to ID a 71 Power Brake booster? [Re: ek3] #2903245
03/26/21 11:54 PM
03/26/21 11:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Hemi Engine = Black Bendix Booster
Midland Ross Boosters like stated where Cadium Plated
That EBay auction someone just spray painted rattle can black a Cadium Plated Midland Ross Booster
Did 440 cudas come with Midland Ross brake boosters from the factory in 71?
Yes the Midland was used on drum (4 whl) and disc/drum cars, only the Bendix was used on HEMI equipped cars...
PN#3461287 4whl drum
PN#3579272 disc/drum cars
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: OK How to ID a 71 Power Brake booster? [Re: bee1971] #2903314
03/27/21 09:32 AM
03/27/21 09:32 AM
Crook County, ILL
Crook County, ILL
The hemi cars used a unique and valuable Bendix booster and master cylinder. Both carryovers from 1970 and both painted black.
Some 71 non hemi E bodies got the carryover from 1970 model year standard Bendix boosters, which are black. But most seem to have the Midland Ross booster which is plated. I’ve never seen a Midland Ross painted black, so the one on eBay must have had a rattle can paint job done in it at some point.
1971 is a very interesting year for E bodies because many things changed on them over the course of the production year. Some things like the changeover of the 340 engine from one plant that painted them orange, to a different plant that painted them blue, are well documented. Others like the booster are more of a mystery, 2 manufacturers were used, but was there a definite transition time on the line, or were both installed concurrently for a time?
Re: OK How to ID a 71 Power Brake booster? [Re: bee1971] #2903315
03/27/21 09:32 AM
03/27/21 09:32 AM
SC
V194 Offline OP
V194  Offline OP
SC
I agree.
Re: OK How to ID a 71 Power Brake booster? [Re: V194] #2903388
03/27/21 02:35 PM
03/27/21 02:35 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Where in the hell does someone find 1971 N O S 41 Cadium Plated Midland Ross Boosters kit like that ??
Man sign me up , weight in gold no pun intended
Siberian Huskies
Re: OK How to ID a 71 Power Brake booster? [Re: bee1971] #2903416
03/27/21 04:37 PM
03/27/21 04:37 PM
italy
antonellomopar Offline
italy
My 71 Cuda 383 4 speed, with 22.000 miles, bought with 17.000 miles in 1985 has a Bendix painted black. Built January 15. ALso my 71 Challenger 440 six pack has a Bendix in black, but more miles and just bought..so not certain if it was changed. But car has been on storage for several decades...tires are late seventies with thread in brand new condition. So probabli it has never been changed. Built march 71
Re: OK How to ID a 71 Power Brake booster? [Re: antonellomopar] #2903432
03/27/21 06:48 PM
03/27/21 06:48 PM
Highland, MI.
Highland, MI.
I was looking at Rock Auto last night, & they have boosters listed. Some are send yours in & it gets rebuilt, & you get yours back. Some are just indicated to be rebuilt units, but all look to me like OE. I've never paid enough attention to them to be able to ID a Midland Ross from a Bendix. Check em out.
Re: OK How to ID a 71 Power Brake booster? [Re: bee1971] #2903506
03/28/21 06:47 AM
03/28/21 06:47 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
They come from the dealerships parts Dept long long ago. It seems like “ in a galaxy far, far away, as well. I had a buddy that worked at the local dealership that really liked me. He was the owners son and loved muscle cars. I had a 70 AAR and a Superbird at the time. I could go in and buy parts at a slight discount all the time. When Chrysler was going through the turmoil of the 80’s bankruptcy, he sold me all kinds of parts real cheap. They were cheap even for that day. I bought 4 each of the masters cly for my 70 Bird and my 70 Cuda. I also bought four 70 style sure grip units and four 71 brake boosters. The 70 booster was no longer available. One was in a kit like the one pictured. The cost for all this stuff? $25 for each. I bought heads, W2 stuff, you name it. This was before I was married. Hemi stuff was scares and I did not need any of that. Some guys had foresight and money. They bought lots of stuff.
Re: OK How to ID a 71 Power Brake booster? [Re: fastmark] #2903628
03/28/21 01:44 PM
03/28/21 01:44 PM
Crook County, ILL
Crook County, ILL
Just for reference, here is a ‘70 and some 71 E body not hemi Bendix brake booster.
