Page 3 of 5 1 2 3 4 5
Re: Oil Change Question [Re: dOoC] #2900880
03/19/21 08:01 PM
03/19/21 08:01 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
TROLLING? ... is asking you to share info you said you had ?
And now you mention that the 6.4 shouldn’t have MDS ?
I’ve had very good results with mine ... [/quote]
Doc, dont play dumb you know exactly what I'm talking about with the way you inquired. Im pretty sure I laid it out for you.Thank you, I will do as I see fit with my cash, as you have with yours. And I'm glad you have not had any problems with your mds. I wish you the best with your rig.
Re: Oil Change Question [Re: moparjim79] #2900916
03/19/21 09:19 PM
03/19/21 09:19 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
EXCUSE ME for asking a question from someone who proclaimed he had done a ton of research on these oils and the requirements of the SRT cars .... tsk
Re: Oil Change Question [Re: dOoC] #2900984
03/20/21 08:13 AM
03/20/21 08:13 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Doc I'm not here to have a back and forth like this with anyone, cool your engines.
On that note, I would like to also point out that some of the forums that I extracted RESEARCH from did have and may still have live Q/A sessions with members of the SRT engineering team on occasion. Something to look into.
Re: Oil Change Question [Re: moparjim79] #2901097
03/20/21 02:57 PM
03/20/21 02:57 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
But mopJ ... back and forth IS WHAT these Internet forums are ALL ABOUT tsk
Why not post a few links on any of those informative articles?
I have some interesting screenshots to post later
Re: Oil Change Question [Re: dOoC] #2901562
03/22/21 11:59 AM
03/22/21 11:59 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
No offence taken, So if I did choose to run Amsoil I could without hurting my warranty? not sure, but just asking.
I did get the oil changed and was asked are you sure you want your oil changed with only 1300?? I asked "if i don't will i have any warranty issues??????" he said you better change your oil. I said lets not put off to tomorrow what you can be doing right now. total bill $108.64
Not bad plus I got to spend the entire afternoon and evening of uninterrupted time with my wife!!! that is priceless!!!
Thank you
Kiddart
Re: Oil Change Question [Re: Kiddart] #2901742
03/22/21 07:01 PM
03/22/21 07:01 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
$108??? Totally worth it. You're time is valuable. Let someone else do it and these are the same people that see these cars everyday so they can tell you if something is out of place. Now when your warranty runs out, thats an expensive oil change. Since they are in bed w pennzoil, amsoil probably won't cut it.....even though its a superior product.
Re: Oil Change Question [Re: moparjim79] #2901953
03/23/21 11:04 AM
03/23/21 11:04 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
That's how i feel!!
Thank you
Kiddart
Re: Oil Change Question [Re: Kiddart] #2902846
03/25/21 11:49 PM
03/25/21 11:49 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
It all depends on what your time is worth TO YOU ......
The first time I set up the oil change was about 2 hours total .... setting up the rineno ramps ... then the additional 2x4 lead ups to those....
THEN using those and having to lift one side slightly.....
The second time ... 30 minutes ... ON THE GROUND ....
My cost .. V 12633 oil with the Mopar filter ... 45 beans ....
108$ at a dealer ? ... I’ll GLADLY pay meself 100$+ per hour !
And I’ll KNOW the job was done right !
Re: Oil Change Question [Re: moparjim79] #2902847
03/26/21 12:02 AM
03/26/21 12:02 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
mopJ ... BUT HOW about the time spent at the dealer ?
I called a dealer ... it’s about a 30 minute job .... THAT IS IF they have an opening ...
I asked them RIGHT NOW .... wait time was about an hour ... plus the time it takes to do the actual task
Amsoil superior ? ... pray tell !
Re: Oil Change Question [Re: Kiddart] #2902999
03/26/21 01:10 PM
03/26/21 01:10 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
So you got Defective oil from the start? "It was old"... Sounds like a Warranty oil change to me.... lol
How many times did it get changed While sitting before it was sold.. Zipp i bet...
Someone is out in left field.... Oh Boy..
Drive it and have fun with it... Cheers
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Oil Change Question [Re: racerhog] #2903013
03/26/21 01:43 PM
03/26/21 01:43 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
So HOGster .. jsta DRIVE IT and don’t worry about the warranty? PAST the initial drive ??
I’d like to hear from people who have gone in that direction. NOT to abuse the car and not do proper maintenance.... I’m not suggesting NOT using the correct engine oil.
LIKE .. putting a light duty trailer hitch on it for a bike rack or towing a jet ski ....
Re: Oil Change Question [Re: dOoC] #2903026
03/26/21 02:12 PM
03/26/21 02:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
LOL, smile I cut off my mufflers & it had less than 500 miles on it & changed out my rear disc pads because the factory ones dont touch on about .5inch of the outer part of the rotor, solved that sh_t
Re: Oil Change Question [Re: CSK] #2903104
03/26/21 06:21 PM
03/26/21 06:21 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Doc Fiberglass my hourly rate is much more than $108 per hour. so it was money well spent. this is a toy not a daily driver. and if you need to know, i also bought the 10 year warranty as well for the extra money. it is piece of mind for me and my wife not anyone else. so yes my time is worth plenty.
Racer Hog the oil was only a few days old, the car came off the line and onto the transport truck the first week of September shipped to the dealer unloaded on the 9th of September and i took delivery on the 11th day of September 2020. the car is a one of one according to FCA records and a total 419 Scat Pack 1320's were built in 2020, so i think the car is worth giving it some respect and tender loving care from my eyes.
I am not sure why or how this thread became a cost of the oil change to the worth of ones time. I love being on Moparts but sometimes most just need to not worry about others financial situations.
I appreciate all the concern and comments and have read them all carefully as to not twist them.
it comes down to warranty and i don't want to screw that up at all.
thank you all
Thank you
Kiddart
Re: Oil Change Question [Re: Kiddart] #2903234
03/26/21 11:27 PM
03/26/21 11:27 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
WELL good fur YOU ..,, 3 ninety TWO !
Ten year warranty??!!
But STILL .... if it’s TIME that’s most important... DIY still wins that battle tsk
The time driving to the dealer and the waiting for them to get it on the rack then actually doing the OC.
AND be sure they use the 12633 oil !
Now if you don’t like getting your hands dirty .... thats anutter story
Re: Oil Change Question [Re: Kiddart] #2903279
03/27/21 06:32 AM
03/27/21 06:32 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Originally Posted by 392Hemi
Hi All,
Need some advise all my other cars get oil changed at 5000 miles according to service records and manual. I have not opened up the manual because i want to keep things preserved as delivered best i can.
what say you??
Manuals are available online as a pdf download. I change my cars according to the manuals. I never hit the mileage, but do it based on time frame in the owner manual or when the light comes on. I have lifetime powertrain warranties on 2 of the 3 and don't want to void the warranty over saving $40 (or what ever it costs) for an oil change.
Re: Oil Change Question [Re: dOoC] #2903393
03/27/21 02:51 PM
03/27/21 02:51 PM
BDW Offline
BDW  Offline
This is exactly why I do it myself, hate waiting on dealer, they're always trying to sell me another car or something else too while I'm waiting.
And honestly, I really don't trust them either. Last time I had an alignment done, I found a 18mm wrench in the engine compartment when I got home, and that was on my 70
Re: Oil Change Question [Re: dOoC] #2903625
03/28/21 01:42 PM
03/28/21 01:42 PM
racerhog Offline
racerhog  Offline
Service it at the proper intervales... Use the recommended Lubricant... Hope you don't have to worry about using the warranty..
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Oil Change Question [Re: CSK] #2903627
03/28/21 01:44 PM
03/28/21 01:44 PM
racerhog Offline
racerhog  Offline
Sound like someone stole your catalytic converter to me... Hot commodity now days...
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Oil Change Question [Re: racerhog] #2904519
03/31/21 10:00 AM
03/31/21 10:00 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Clarify please ! ... proper lubes are a given !
Re: Oil Change Question [Re: dOoC] #2904522
03/31/21 10:03 AM
03/31/21 10:03 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
I gus we will all haveta wait on the explanation on the statements about ...
Amsoil being a superior product... and that 10 year warranty.... whistling
