Windage Tray w/ a Girdle? #2902267
03/24/21 07:37 AM
03/24/21 07:37 AM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Quick question. Building a 470. Primarily a track motor. Ordering a girdle. Do I still need to mess with a windage tray? Planning to use a 7qt pan and probably spinning the motor to 6700-7000 at the stripe.
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902306
03/24/21 10:27 AM
03/24/21 10:27 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
no the purpose of the windage tray is keep the oil in the pan from whipping up and foaming from the crank rotation. having a girdle sandwiched in there and deep 7 qt pan, the oil should be far enough away that it won't have any whipping. if you're really serious add a crank scraper.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902313
03/24/21 11:00 AM
03/24/21 11:00 AM
Nevada
merpar Offline
merpar  Offline
Nevada
The most important thing you can do is oil control. Get a good oil pan with baffles to keep the oil around the pickup. Most damaged engines are from loss of oil at the pickup. The windage tray may help the oil from foaming and the girdles that bolt to the pan rails are worthless. The windage tray and girdle are my opinions. But a good oil pan with oil control is fact. from my experience's and seeing other engine failures. The 470 is an excellent combo, good luck with it.
Re: Windage Tray w/ a Girdle? [Re: merpar] #2902328
03/24/21 11:52 AM
03/24/21 11:52 AM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
I will definitely look into a good pan. Thanks. Planning to go with a single line external setup. I’m going to skip the windage tray deal.
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902373
03/24/21 01:18 PM
03/24/21 01:18 PM
Why are you buying and using a girdle on a BB Mopar?
I would use that money to buy a good block instead of trying to patch a stock block twocents
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902403
03/24/21 02:43 PM
03/24/21 02:43 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Why the external line, is your pickup boss messed up? Not worth the headache, definitely not required for those RPMs based on my experience.
$450 vs $6500 + machining? Hmmmmm.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Windage Tray w/ a Girdle? [Re: A39Coronet] #2902462
03/24/21 06:38 PM
03/24/21 06:38 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
I could certainly skip the external line. I think I have a cover but I'm all for simple and reliable. Just don't want to have an issue at the top end when it's pushing 7k at the stripe.
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902529
03/24/21 10:19 PM
03/24/21 10:19 PM
I use to shift my pump gas 400 stoker motor(518 C.I., 727 HP at 7300 RPM) at or above 7000+ RPM on every run, 1000s of them with a stock Mopar 1970/71 440 6 pack B&E oil pan (6 quarts in the pan, one in the filter) with the stock 3/8 inch internal oil pickup up
I did add one of my home made crankshafts scrapers with a stock OEM Mopar windage tray up
I did use a set of Mopar brand Ductile iron main caps (no longer available now whiney) with ARP main studs and I had the #4 cam journal groove all the way around the oil hole to oil the rockers full time to help cool the valve springs, I ran a Comp Cams custom grind solid roller cam with PAC valve springs with right at 275 Lbs. on the seat s and around 650 Lbs. opened at .700 net lift. That motor and car exceeded my expectations by a bunch boogie 10.001 at 134.6+ MPH corked up with the full 3 inch exhaust and air cleaner on weighing 3450 Lbs. with me in it running Oregon 91 octane pump swill, non ethanol back then up
All the main girdles I've seen do nothing to fix the main webbing weakness, they(stock blocks) still crack with them on between the main webbing and the bottom of the cylinders shruggy whiney
Re: Windage Tray w/ a Girdle? [Re: Cab_Burge] #2902548
03/25/21 12:47 AM
03/25/21 12:47 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I have a windage tray, a Hughes stud girdle and a 7 qt Milodon 30930 pan... it's hard to keep it from leaking somewhere.
Thinking of removing the girdle (I'm making less than 600 hp). But I also want to add a small (less than 150) shot of nitrous.
Does the girdle not help at all? shruggy
Re: Windage Tray w/ a Girdle? [Re: DrCharles] #2902553
03/25/21 01:30 AM
03/25/21 01:30 AM
The only help I can see with most of them is it holds the main studs from moving front to back, not much else help I can see shruggy
It does lighten the owners wallet a little also whistling Just Kidding unless the owner is the driver also work whistling
AKA at under 650 HP you should be good with good main caps and main studs up twocents
Re: Windage Tray w/ a Girdle? [Re: Cab_Burge] #2902588
03/25/21 08:19 AM
03/25/21 08:19 AM
an8sec70cuda Offline
Even w/ a girdle, I'd still use a windage tray. As limited as the BB Mopar is w/ oil pans to control windage, it needs all the help it can get. I don't see the thickness of the girdle helping all that much.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902602
03/25/21 09:30 AM
03/25/21 09:30 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I have one on mine but having problems attaching pics, even with "Attachment Manager"
Re: Windage Tray w/ a Girdle? [Re: 67_Satellite] #2902606
03/25/21 09:41 AM
03/25/21 09:41 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Girdle does nothing for oil control!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Windage Tray w/ a Girdle? [Re: hemi-itis] #2902637
03/25/21 11:22 AM
03/25/21 11:22 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
A while back,someone made a BB girdle that, looked oversized or poorly made. Had one on a BB that I was building. Assembled the motor and off to the dyno. Motor made about 550HP in those days. Pulled the oil pan and forgot to replace the girdle. Lost 15+/-HP. I made about about 5 to 8 passes before the pan came off. After some head scratching, and oil filter change, got back 12HP. Discovered that I never added the quart or so of oil from the filter change. Assumed that the girdle had some type of scraping effect.
Re: Windage Tray w/ a Girdle? [Re: A/MP] #2902646
03/25/21 11:44 AM
03/25/21 11:44 AM
You forgot to reinstall the girdle? Or forgot to reinstall the windage tray?
CHIP
Re: Windage Tray w/ a Girdle? [Re: an8sec70cuda] #2902845
03/25/21 11:26 PM
03/25/21 11:26 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Forgot to install girdle. There was some weeping either at the pan or the girdle. The flange to the pan was straight so I opted for the girdle removal.
Re: Windage Tray w/ a Girdle? [Re: 80fbody] #2902938
03/26/21 10:14 AM
03/26/21 10:14 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Anyone with 1/4-20 pan rail bolts?
Easy upgrade is to 8mm X 1.25mm, substantial increase in X-sectional area and 98% thread match.
Boffin Emeritus
Re: Windage Tray w/ a Girdle? [Re: polyspheric] #2902942
03/26/21 10:28 AM
03/26/21 10:28 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
8mm and 5/16 are similar in size.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Windage Tray w/ a Girdle? [Re: Jerry] #2903010
03/26/21 01:31 PM
03/26/21 01:31 PM
iagree shruggy
Re: Windage Tray w/ a Girdle? [Re: Cab_Burge] #2903016
03/26/21 01:51 PM
03/26/21 01:51 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
iagree shruggy
Agreeing with a fact, intellectual rascal you are.
