Re: Pro trans fluid
[Re: RO23dave]
#2901771
03/22/21 08:12 PM
03/22/21 08:12 PM
Posts: 133 Winter Park, Florida
classracer
Per Dave Smith " you have the trick tranny, you don't need the trick fluid. I use a brand name type F and change it every 15 to 20 runs. Good Luck....Jim
70 Challenger A/SA 2441
Re: Pro trans fluid
[Re: RO23dave]
#2901822
03/22/21 10:42 PM
03/22/21 10:42 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Valvoline Type F non synthetic ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) If it starts to turn color or smell change it Is this car a Street Hemi or M.W. car? Stock type street and strip Pro Trans or one of his all out his race parts tranny? Do you monitor and record tranny fluid temps? If so once it gets near(290+F) or above 300F I change it in my S/P car with a glide in it ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Re: Pro trans fluid
[Re: Cab_Burge]
#2901826
03/22/21 10:49 PM
03/22/21 10:49 PM
Posts: 11,714 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Petroleum Type F or FA. Valvoline. Change it frequently. I've heard of all kinds of fluid being used in the big horsepower units - Pro Mod, RVW, Pro 275, etc - hydraulic oil, shock oil, compressor oil.... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Re: Pro trans fluid
[Re: RO23dave]
#2901838
03/22/21 11:27 PM
03/22/21 11:27 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I recommend LAT tranny oil...
Brian Hafliger
Re: Pro trans fluid
[Re: Brian Hafliger]
#2901880
03/23/21 06:51 AM
03/23/21 06:51 AM
Posts: 9,882 MI, usa
dvw
MI, usa
JR1 synthetic. Changed once a year at about 100 passes Been running the same band and aluminum drum for over 500 passes. Both look like new. Clutch life is great. Motor makes around 900. Doug
Re: Pro trans fluid
[Re: cl440]
#2901962
03/23/21 11:08 AM
03/23/21 11:08 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
We use ATi20W in the Vettes Proflite
Re: Pro trans fluid
[Re: RO23dave]
#2901970
03/23/21 11:29 AM
03/23/21 11:29 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I used to use Mobil 1 Synthetic but for the past 10 years per the advise from my tranny builder I've been running O'Reilly's type F and every freshen up looks perfect. Told me to quit wasting my money. Run the whole year on same fluid, don't change engine oil all year either.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Pro trans fluid
[Re: RO23dave]
#2902101
03/23/21 04:11 PM
03/23/21 04:11 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
Been running Dextron since the mid 80's. The trans was in my cuda from 2001-2006. The car was nothing special ran low tens. The trans sat for about 8 yrs when life got in the way. In 2013 took it in to be checked and rebuilt if nec was told other than a few minor adjustments everything was fine. Been running it ever since in my wagon. Its not as fast but is a heavy pig. Nothing but routine fluid changes.
Ok
Re: Pro trans fluid
[Re: RO23dave]
#2902113
03/23/21 04:53 PM
03/23/21 04:53 PM
Cab_Burge
Call Dave and ask him what they recommend now for your deal ,661-940-7400 ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
Re: Pro trans fluid
[Re: WadeMetzinger]
#2902224
03/23/21 11:35 PM
03/23/21 11:35 PM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
I used to use Mobil 1 Synthetic but for the past 10 years per the advise from my tranny builder I've been running O'Reilly's type F and every freshen up looks perfect. Told me to quit wasting my money. Run the whole year on same fluid, don't change engine oil all year either. Ow there’s a man that’s smart
Re: Pro trans fluid
[Re: WadeMetzinger]
#2902310
03/24/21 10:43 AM
03/24/21 10:43 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I used to use Mobil 1 Synthetic but for the past 10 years per the advise from my tranny builder I've been running O'Reilly's type F and every freshen up looks perfect. Told me to quit wasting my money. Run the whole year on same fluid, don't change engine oil all year either. Wade do you have aluminum drums? Thanks, Bill
Re: Pro trans fluid
[Re: 340Cuda]
#2902716
03/25/21 02:19 PM
03/25/21 02:19 PM
WadeMetzinger
Tulsa, Ok
I used to use Mobil 1 Synthetic but for the past 10 years per the advise from my tranny builder I've been running O'Reilly's type F and every freshen up looks perfect. Told me to quit wasting my money. Run the whole year on same fluid, don't change engine oil all year either. Wade do you have aluminum drums? Thanks, Bill No, Steel billet drums in both my PG and 727.
Re: Pro trans fluid
[Re: SCDaytona]
#2903353
03/27/21 12:10 PM
03/27/21 12:10 PM
340Cuda
Tulsa, Oklahoma
Dave told me to run Type F fluid in my ProFlite so I use Amalie Type F. How often did he tell you to change it? Do you have aluminum drums?
